REHughes
I would appreciate some help from any of you that have experience with the later-style 6-bolt engine mounts for the -3. I am at the stage of fabricating the angles that run up from the cockpit floor to the backside of the firewall, the assemblies that provide the pads to mount the two "extra" (toward the center) engine mount bolts. The plans are basically worthless in determining the location of the firewall holes for these two bolts... The critical dimensions vary widely between drawings, and are not even consistent within the same drawings, including the one for the mount fabrication.
If anyone has their cowling off at some point, would you please provide me with:
1. The distance from the lower firewall flange up to the centerline of those two bolts.
2. The distance between the two bolts.
I am not ready to make the conical/dynafocal choice, so I can't buy my mount yet to do a custom fit. I am not going to drill the bolt holes, but want to make sure they will eventually hit the right portions of the firewall reinforcing angle pads.
Thank you very much, Hawkeye
