Aircraft jacks for RV-7
FutureRV
Member
Any recommendations for purchasing a aircraft jack? I want to remove main bear wheel to grease and inspect.
David
Are you up for a DIY solution?
If you are willing to put in a little work Kiitplanes recently posted an article on a do-it-yourself aircraft Jack set for RVs. If you're a kid Kitpanes subscriber you can just go on their website and get the article. If you're not, private message me with your email address and I'll send the article to you. I strongly recommend subscribing to Kitplanes for anyone on this list. It's well worth the money.
Charlie
Charlie
Will check out the Kit Plane article. Thanks
I have this one and like it
Check out these guys. " wintermotorsports.com" . I have this on my build. Was going to build one, but this one allows you to jack up on the road with a simple sissor jack or floor jack. Easy to install and light to carry around.
If I don't feel like using the lever with gear leg cradle I bought from someone in here, I just hoist the plane at the engine mount with a Harbor Freight engine hoist and 2 foot strap. Works very well.
Jacking for wheel and brake Maintance
Wintermotorsports.com
And Flyboy accessories carry the Jackpoints.
The article is in the September 2015 issue. Like I mentioned before if you can't get your hands on it just send me a private message with your email address and I'll send it to you.
