The Lycoming school has a home-made slide hammer that works great for this. They welded a socket that fits the large through-studs on to a regular slide hammer. You screw it on the studs, and bang away, pulling the studs. Then remove all the case edge bolts (including the one behind the cam gear!), and the case pretty much falls apart.
Paul
