Captain Cowboy
Member
Recently while flying Card 2 Accept. test, started getting EGT 1 Alarms about every three seconds and then they would reset before I could clear them myself. I noticed that the green switch lights for Master, Avionics, Ignition, Autopilot lights would go out when alarms came and when I could clear the alarms they would return on as normal. This happened almost continuously until I could land and terminate the profile. Replaced the connnector from egt sensors to back of dynon and flew next card normally. Now have same indications back again. Noticed when get ready to fly and select master to on position, no green light on switch, then select avionics switch to on and no green light, then dynon powers up and green lights cycle 3 times before coming on steady until Dynon start alarms set then the green switch lights go off. Have 20 hours on 12 and this started at about 18 hour point. Called Vans and Dynon about this last evening. Vans now looking for cause, Dynon says it might be the Honeywell oil sender causing shorts on AV Bus and causing erratic indications. Has anyone had similar problems? Has anyone had a bad AV Bus that had to be replaced on the 12. Looking for any help from all you guys out there that really know the 12 electronics system and its interconnectivity. If you can help, email me at [email protected]. Thanks for any help. A very frustrated builder/pilot! We are the guys that got the wrong oil tank with our engine and chased that oil leak ghost for monts also. I guess, that is why they call it Experimental. BTW, the aircraft performs much better than I could have every expected with my 20000 hours of flying experience!
Doug Robison
Doug Robison
