yankee-flyer
I know this subject has been beaten to death, but its just happened to me. Original pump, original fuel pressure sender, Dynon 5.3 version, 149 hours. Just completed the Condition inspection, no hint of fuel pump leaking (the foam tie-wrapped under the weep hole is intact). During the inspection I opened the 4 spade connectors in front of the firewall (I think two of them are for the sensor) cleaned them with Deroxit, and put them back together tightly. Same for the 4 spade connectors at the Red Cube. Cleaned the gascolator-- nothing there. Just 1 hour into the post-inspection check flight I got the high fuel pressure alarm-- about 5.7-5,8 psi. Pressure check at idle and 4000 RPM before takeoff was normal-- high 4-low 5 psi. Pulling the power back dropped pressure for about a minute, then it built up to alarm values again. Continued to "silence" the alarm and it continued to go off every 30 seconds-- very irritating to say the least! Even went off on short final with power at idle. On the ground I pulled the electric fuel pump fuse and the reading dropped to about 4.3 and stayed there regardless of engine RPM.
I've read the archives and will switch to ring connectors but have a feeling I'm in for a new sensor. Really, REALLY don't want to do that as I'm virtually computer illiterate and have never been able to load anything on my Dynon. I could download the files onto my PC and put them on a CD for the laptop, but getting then from there into the Dynon is most likely going to screw something up big time. Not to mention that I don't have a clue about "locked files"!
Any other suggestions besides just disabling the alarm? Never had another airplane with a fuel pressure reading nor one with both an engine-driven and full-time electric pump, so this seems like too much information to me.
THANKS
Wayne 120241
THANKS
Wayne 120241
