Old 08-10-2015, 08:33 PM
Pat Hatch's Avatar
Pat Hatch Pat Hatch is offline
Default Mounting the Magnetometer in the Wingtip
So we're talking about where to mount the two magnetometers in Bob Lund's RV-8. Jason Smith at Aerotronics suggested that a tail mount of a Garmin magnetometer is not passing the interference check during calibration (we're talking RV-8--tail location is fine in my RV-6). Steve at GarminX was also very encouraging. So we decided to try a wingtip mount in spite of the heavy iron pipe that is in the leading edge of the ailerons. That was a concern. Here are some pictures:
And the GRT Mini magnetometer installation in the opposite wint tip:
We did the Garmin Magnetometer Interference Test today for the first time and it passed! The highest interference level we got was 64% of the limit during full left aileron deflection, but apparently it was still well within the limits. We will report later on the GRT magnetometer results when we get to it.
We rolled the airplane out of the hangar today for the first time, ready for first engine start in the morning. More later.
Pat Hatch
RV-4 (Gone to RV heaven)
RV-6 (N44PH - Flying)
RV-7 (Sold)
RV-8 (Helped build Bob Lund's airplane)
www.phaviation.com Trim Relay Boards/Flap Actuators
www.pathatch.com/blog (Photography)
Track Me
Old 08-10-2015, 11:47 PM
SMO's Avatar
SMO SMO is offline
I need to mount these two magnetometers as well and was going to put them both in the same wing. Did you consider mounting them both in the same wing? Is there a reason it should not be done?
Mark Olson
1987 RV-4 Sold
2003 Super Decathlon - Sold
F1 EVO Rocket, first flight May 31/14
Old 08-11-2015, 05:40 AM
1001001's Avatar
1001001 1001001 is offline
Do you see any effect on the magnetometer when the strobes discharge?
Old 08-11-2015, 05:52 AM
Pat Hatch's Avatar
Almost none (2% was what I recall). If I had to do it over, I would have moved the magnetometers forward more because of this, especially since our strobes are LEDs. But I was concerned about the strobes, nav and landing lights in the wing tips.
Pat Hatch
RV-7 (Sold)
Track Me
Old 08-11-2015, 09:06 AM
maus92 maus92 is offline
I have the GMU22 in my RV-8As wingtip, but mounted a little farther forward. My biggest source of interference is the landing light, but it's still well within limits. Both the landing lights and position/strobes are LED.
CA
2000 RV-8A | O-360, FP, G3X Touch, VP-X, EarthX
Eastern Shore | KESN
Old 08-11-2015, 09:34 AM
RV8iator's Avatar
RV8iator RV8iator is offline
Default Just a data point
Guys, just another data point for your consideration.
I had my Dynon D10A magnetometer mounted in the right wingtip and it seemed to work fine. Of course, I didn't have much to compare it to.
When I changed to GRT MiniX's I put the magnetometer on the same mount in the right wing. During calebration it seemed to work fine and showed that it was a good place. However, it actual use I had large (10-15 degree) variations with my HXr. (HXr magnetometer mounted in fuse about 12" behind baggage real wall). My variations occurred only on 45 degree's off cardinal headings, and was worse to the SW. I moved the magnetometer forward in the right wingtip to get away from the aileron rod and that didn't change anything.
I finally just mounted it next to the one in the rear fuse and now they are both exactly the same on all headings. I've swung it a couple times and they match compass roses and runway mag headings exactly.
I'm just throwing this out. In my 8 I could not get the wing mount to give accurate headings.
Best
Jerry "Widget" Morris
RV 8, N8JL, 2600+ hours
VAF #818
Saint Simons Island, GA. KSSI
PIF 2008, 2009, 2010, 2011,2012, 2013, 2014, 2015, 2016, 2017.
I just wish I could afford to live the way I do
Old 08-12-2015, 07:03 AM
Default Us too.
We just did this one with the Garmin unit a couple of months ago. The wing tip works well if you mount the unit halfway between the spar and the back of the main wing body. The only thing we found was for the strobes and other lights in that wing tip we needed to run a ground wire into the main center section of the cabin, for all the lights and strobe. If you don't use the wing as your ground conductor from the outboard end of the wing, there will not be an electrostatic field in parted to the wing structure close to the magnetometer. The only thing that you have then, close to the unit is the steel in the hinge bolts, counter balance weight, and wing tip screws ( use stainless ). We got 30-40% or there about.
Hope this helps. Yours as always. R.E.A. III #80888
Old 08-11-2015, 05:41 AM
Pat Hatch's Avatar
Mark, I would say it would be fine but I'll defer to the experts. I have mounted magnetometers together in the past with no issues. Given the choice, however, I would want to eliminate any possibility for interference.
Pat Hatch
RV-7 (Sold)
Track Me
