Old 12-12-2017, 07:17 AM
N329JR's Avatar
N329JR N329JR is offline
Default Is there a tool for this ???
Does a tool exist that can be used to burnish / polish the sealing nose of a 37 fitting?
I have an AN833-6D bulkhead fitting that is installed and encapsulated in cured tank sealant. Apparently during my installation process, I inadvertently introduced a circular scratch in the sealing face of the fitting while torquing the bulkhead nut. I know that I could use a DEL Fitting Seal for this application, but it still seems prudent to attempt to burnish or polish out the scratch in the 37 sealing face. My interweb searches have yet to uncover such a tool. If one does not exist than I suppose that I will polish out the scratch by hand.
Thanks in advance for any input based on experience with a similar situation.
I am of course trying to avoid major rework including tank sealant removal.
Ian
RV-3B My RV
RV-6 (Dad's RV)
RV-8 Empennage 95%, Wings 95%, Fuse 2%
2019 VAF Gladly Paid
Old 12-12-2017, 08:28 AM
Raymo's Avatar
Raymo Raymo is offline
I think you could use a piece of flared tubing (maybe over-flared) and some fine Emery cloth or similar to carefully buff out the scratch.
Also, consider calling Tom at TS Flightlines for an expert opinion.
Ray
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
All lines by TSFlightLines
Old 12-12-2017, 09:18 AM
Ron B. Ron B. is offline
There are little thin seals that you can purchase that go between both parts for situations like yours. ACS use to carry them. Just looked them up they call them Del fitting seals.
Thanks Ron
RV-10 SOLD
RV-14 Flying
Old 12-12-2017, 09:21 AM
Don Patrick's Avatar
Don Patrick Don Patrick is offline
Default Here
https://www.aircraftspruce.ca/catalo...?clickkey=9080
RV-8 build
DONE!
C-GLOV
http://www.mykitlog.com/Don%20Patrick
2018 donation contributor.
Old 12-12-2017, 09:49 AM
Del Seals---Spruce, and others have them.
Tom
Ridgeland, SC
Old 12-12-2017, 09:55 AM
N329JR's Avatar
Thank You guys!
That just confirms that everyone is in agreement that I can safely use the DEL Fitting Seals with confidence.
I may try to cautiously burnish out a bit as well first.
Building On.
Ian
RV-3B My RV
RV-6 (Dad's RV)
Old 12-12-2017, 07:01 PM
VA Maule VA Maule is offline
Very fine Valve lapping compound + very straight flaired tubing + close fitting alinememt pin / dowel + patience + drill with a steady hand.
Probably lot easier just to get some DEL seals.
Maule MXT-7(daily flyer)
Lancer 235(partner)
Raidial RV-8R Ephanage Done, Wings Done, Fuselage on it's tall Grove gear & engine hung
Old 12-13-2017, 05:05 AM
bobnoffs bobnoffs is offline
fwiw i had a fitting leak and continued after fiddling with torque on fitting. i already had del seals on hand so i used one and leak stopped .
i think i would try one before changing the mating surfaces of the fitting.
Bob Noffs
n. wi.
dakota hawk/jab 3300 built and flying. sold 6/18.getting serious about the 12.
RV-12 kit as of 9/13
