burgessbuilderMO13
Just received a new hartzell governor from Van's. The thickness of the mounting flange is equal to the length of the mounting studs, which leaves zero stud length available for washer and nut.
The engine is a rebuilt 540, that has previously had a governor mounted on it, but apparently not similar to the new one. Has anyone had this issue, what new stud length is required to replace the current pieces. How long are the studs on engines supplied through Van's?
Dale
Dale
