rvator51
Below is a graph of the different readings of the resistive
Vans senders while calibrating the fuel tanks for the new Skyview system.
I was expecting more of a curve from these readings versus almost straight lines. It looks like on the right tank, that the readings might be off a little on the 8 and 11 gallon readings. Wonder if the sender is sticking a little?
Would be a nice feature on the skyview if we could go into the calibration settings and manually adjust/enter them again.
