Old 11-04-2017, 08:32 AM
Larry DeCamp's Avatar
Larry DeCamp Larry DeCamp is offline
Default Flush rivet appearance quality?
I purchased a project with ALL skin rivets that LOOK like they were back riveted. I cannot reproduce these results. My ATS gun with high pressure and throttle valve closed as much as it will, still runs fast NOT THUMP THUMP. The rivet head looks shiny ( too much hitting? ). The project I purchased, the factory head looks like it came out of the bag and the little dent looks like never struck, and transition to skin is beautiful. What am I doing wrong ? What rivet gun will do better ?
Larry DeCamp
RV-3B flying w/ carb / Pmags / Catto 2b / Steam
RV-4 fastback w/ Superior XP360/AFP/G3X/CPI/Catto3b
Clinton, IN
Old 11-04-2017, 08:49 AM
wilddog wilddog is offline
Larry,
What psi are you running and is your gun 2X or 3x?
Old 11-04-2017, 09:30 AM
Default Gun is old ATS
I dont know what model ( 2x,3x, ?? ) I turned pressure up high, 80 lb+ thinking it would deform the rivet without "pecking" at a high frequency, but the the throttle valve is closed and it still hammers fast and I think is hardening the rivet in the process.
Larry DeCamp
Clinton, IN
Old 11-04-2017, 09:45 AM
wirejock's Avatar
wirejock wirejock is offline
Default Rivet gun
The gun should have markings. Post them. One of us should be able to decipher them.
Try a good mini regulator set at about 25 psi for #3 rivets. The little HF regulator is ok.
A good shop head on my Sioux takes about 2 second pulse. Also, try a strip of heavy packing tape over the factory head.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 11-04-2017, 11:09 AM
Larry,
I use 22-25 psi with a 3x gun. I have a 2X but find it hits lighter and faster and requires more hits than the 3x does. The little knob thing on the handle just controls air flow, not pressure, so set your regulator. That is with 426-3 rivets, 470 takes a little more psi. If you are back riveting, it will take more pressure usually about 45 psi , I think, but that will vary with the back rivet thing, longer ones need more pressure. When you do 470 rivets try the little plastic things that go on the set, they help a lot.
Old 11-04-2017, 11:12 AM
BillL BillL is offline
Always use tape, that prevents the shiny look of the set rivet.
Bill
1st Flight 1-27-18
Phase II 8-3-18
Repairman 11-15-18
Instrument Currency 12-17-18
Old 11-04-2017, 01:02 PM
35-40 PSI is what I use on 3/32 rivets. About 60 PSI on 1/8" rivets. 80 is waay too much.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 11-04-2017, 01:12 PM
az_gila's Avatar
az_gila az_gila is offline
Question
Larry said in the OP that he has the throttle valve closed. Perhaps a test with the throttle valve fully open and less psi might be in order?
If it's a slow thump-thump I'm also wondering if the rivet gun is really an air hammer...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 11-04-2017, 02:22 PM
I saw that, but I'm not familiar with a throttle valve.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 11-04-2017, 03:47 PM
az_gila's Avatar
Smile
Sometimes incorrectly called a "regulator" and sold by cheap places such as HF -
https://www.harborfreight.com/air-to...tor-68220.html
It's simply an inline variable restrictor. There is no pressure regulation going on in it for $3.59.
Gil Alexander
