DIY Cleko rubber caps on the cheap....
Ryano
Several months back there was an article in Sport Aviation's Experimenters section, that I can't be bothered to dig out of the "Morning ritual graveyard", covering how to make very low cost Cleko caps.
25LclIz6XSz43qYodV5-nONblLQ4V1sHDaAu7Z4VQEOccD5MzC9XYkpByK1LEsBKT9yJ2NIe4Dd8SPMBDUn_X_qbVQhHaEJsoJxp0NS8M6N_ZzYXmXFOAz7U6MjgZj0QPtrCYbykv0ZdLlFNcdI1sPJFpyziuHok8C7cv0VqQL00TT_I-8mS05JwhJEQzvgzd1hJntExQMi_4FOgCXYPlmsLsJDmattSuqAr2bdAdMtTY1PULN_5sl2oIMtkhixRtn_VIWZE44SlvOFeMI9hfURwPUtAuNPdfAXnuMPLhtJvSqd5EWy5780bb10rCqWo7O5Ea6CNiG8--WvKqMRPtBs2QuW0Ft-4JRlnjmG3pXpVEAhsqpxPVxM2miCNaBSU1BcQfmRMmdI9L6xeK0JCqG1H05WVnKP1FPTcSg8srCwKyEwkQNIeHAl6ArXi1wMbVLrq0Hb1gIaeDC2rHCalcN5dsT-3lGTWpnXUpakIdES-06iQLHOnOhJDKye15eTDhWlDwDlERQGxZKLL9ofhlG1BSUmpyqQksmGbj0cYRRJw-fajg73WHBQVyoS0bgBH5F51agj5O9X1kAHpQ-6MoRS_Sd-N3qlkrd244NU3EWeC8jkdPk3mIN79HAcHnxiwioJei0S1xHiCXWxXCQnp1TTP_v_GWNgXHGE=s800-no
I liked the idea of not spending as much for a rubber cap as the Cleko it was going on, so I decided to give it a try.
First off both the article and video on the EAA's site don't make it clear what exactly you need to order.
If you're starting from scratch, like I was, this is the critical information.
Step one... Order the following.
Go to McMaster-Carr and order..... (price in USD as of 5/17/17)
9753K16 Flexible Vinyl Round Cap 1/2" Inside Height, Fits 5/16"-3/8" OD, Packs of 100 $4.00
19195A22 Awl with Plastic Handle $7.15
2894A64 General Purpose Drill Bit for Wood 7/16" Bit Size, 1/4" Hex, 6" Overall Length $3.17
TtYevpGFBqGLu4dZvMhokBjMd04EbrmwPPmThXk7q_x6JGjykYeugyhLY8LVkmBtutu6vWnaY3mBJamdMwZJA4xKFjEHLpbFRo4erxJ8AY9ekjJ008y8X5SVAyg7c1bzymkf00vtYfRMvmuRpz6_LdURqjITD8QR174qBI4QHh005waTtTyJMkPcQMeIzUI51vgtvgKR7qL-IJ0aLjvH2SgCvIq9yLfpkJ_a3Vve0W8gYSToC7sfMcQdKWvM1hTpBmxvLWU2T_ZVJbm4-s0cqmRqODZlhHnsWuMCTqdgD8JixotcGSeOMS5R4CCrbxmclcbflJPO4ixIVfIFlyUan1gBIWXb-cWZFxj4J7Eqjk8m40_ICgHjBJ9AX4_DDzKpWtTJaVRF1c9ap_DmRS2p3vLS4cCGRYJaUPuzJEZPE-UHQYnDJYAfu8wmljcBYHbVSrMZMCgnRSjhSJqf2eNguyu2QM1p6DlJqhFpgPWpuy2JrmfVsCoqdkp8SswTYXK1w_9NMSHV5UOfxU9lOvWGGEhoaoLIxPY_3wePYMaMFuyI7TBXm6OBYTwUd85iTUw6UUJ7CNmlb2R5vEjTzaTIh90LisnYIR_mfR88pPqcVXgO8o0wjKktcPFvJ2bqwfMATZI9-6ozrCWW2D30cmk8u6o-RZ5Ubfo4n-8=s800-no
Step two... The execution!
The idea is that you drill into a block of wood, insert the cap nose down , and use the awl to punch a hole in the tip. Seems simple enough, but it doesn't work well if you do it like that.
I drilled hole in a scrap block of 2X4 at a depth that I thought would work well.
I found that I was having trouble getting the punched hole to be anywhere near centered.
Step three... The modification!
I flipped the caps to a nose up orientation to better control and center the punch hole location.
ZnfVoH_XeVbwiBSs7bWij7DLw8loc0kVrOmAPOc14YthxgdxoEh5Q_E-guI5OIFz3X2gq3h1k8JC3n-zvVFa6c4Em01F2qneEODX-AKPUeuyfV3wIpmZIthkedMPi42eunHB0-thUu6FJL60jq0TxPkBSVJzrL5-qs1_mXvdt-tAbO1cpcBz_bYhdkDadSE-I0dpV_J9rE2NzoRVWvc0FL33j6r43R_DQgwUWCwQ5PlzWiRQwxNSoHNXOFVm_mDQzWmVDeOPJsOcV23iC2Dkpn5IfgEVkd8ACG4rppelQZKUyvrpwfrvLUQfSpYMvURmfsOeTKzZLKnz7e2hVGng03zD6DbOM0k3CLiKGJRFo3qDDBk0qms_gPH0RX56caW1tbfTjB1YAWAejF4dsnIOTtcM9IgHKGq9AxcIFWR9wki8tOFCCO2jW3oeafiGOgmvMffei9zGKkNwVdzOMBwOPTVL0fzb5Drwa_lppkkdmdMNPEtj_gYskYiEUr9wjeEvPSaHjmLiCqUiR5XtlUHTQbkz49nGxMkEplQeDjah23QzTxT7zx7Il6MojiyMW-E87wy7N3Ih2OyhqCRGDfBEHHYcwBe5KhPLMpWnPZ6iw_NrvgRYfA5u78Oin4ZrpBXsPn7xnWuSTwW_GphaPrFYIx-h2TxZcbSaozU=s800-no
Step four and beyond...
Remove your freshly punched cap from the jig.
yIkOPn_xLVDV44huGOqaQWrJmEjekC8pvxKQClgCW-ALuXi2FaeyVof0khMa4m4SrnLWXI4gekRA6X-rR26b4rxJTXwalsuSlg8u38VPqY-7oMCSKMWo9rNt1zAeofii9RlL9jgt6Yui1wO3sSjGoz_5U0O6Yw8zoSGnHdnQxD6hD3-r6dqUYJoF27qZxJdD0YUuEytA6QNP3hEZIjFV2hxwTjF917mSh_Iw2fOXBCFF6TmOuN2Bx_bRr2uPQ8hW1dUm4PM_uO4tIBddpwUM19GEKTpBUDY1h3SydfEheE4RVp_3fGc6sEc6jaZOqbI0qouYcMf7Ev_WBWPVPlu1OKxflC6rNnRyYEIt8WpNYZyVKqad8ufO50L0f9FmpDHbvFoOJU7sZvKLMAwuv2wcfW49X9eLQx-v7t1oxBe1w1t3PyjSkd4bGPdTJsHj0q2exHQjY4EWHBFmMTGj_iJPoA23tm7_dmTK1GWLls4l2Fq6G7ZbUmVOEmG6Er7dffoknTiLwJRhUnXbFsmPQYhXEdMFOLvAAh6kFuj1L2EnK--6jMzU8_VA1z6hNbK4SkC7WQbq-BCUrw9s45E3usPQrQ7cGbqcGa7yH0jljkxnVQoK-3d3EP-KzkMzMj8R_bloF7wabcVMQwsprIZuAEkucpiYKYBTXOErUE0=s800-no
Fit the rubber cap onto the end of your #40 Cleko as best you can. They don't want to go on easy, so I drilled a #40 hole to clamp into in using the clamping compression to set the cap.
dcvTpTwgpDmb5ll1sKIGRU19IrZ9mCqZI6pwBuwIwXw-AEeedlmHFZyH_kk4HlZweHibfThwF7DGV6Z0uyxBv953E-0UXy66p6anA0fxycG0dRRyP8PhUY_aZQZ3DJwhx2rV8S7-lw0kI6FvQ43lW8xM-tl8vUAhrcbCTcpq3cMoV5ZlboHKOOUgnqEost75BOCgtiBKLwDWA_q6tPXCQHHjBRQavng4IO7c8QskOhlDilHoBN0mKeIm7bFidTobnJ_2OBA5AAYFwcem6p-p2Vn13dEGBPzYQN8hNNJ5wk_uxyj9Gkwh1HZxNICYxuY5bTkUISKhS980eGvMaKv_weG1_gfdVDcgmVz_odTJhlmrUV1-d01dCWH1BVvW8vV8DmTFSXLVehyFAZ7cb08ljo3r00fLunz_8vFPkDjsoBTGr0nUCTRAXVxzoXkG8sk9rVLO1WNcQTzR1oNUsJcXKxsHcFNpe2hAJRn3QSXr5lJjKxpZTdZkyv4grRZZB1bQw_JubiEa_pwQAVsRrqTGSAzaBd0y6G9jURsiOkmNx4RXA4SUAhDb8qvoJIJ_fz7FD3nLdMFDTx3ylJnZgyA22x5THHddoIkfQbN6qlF-AwPcyszGMzWHso02uoKY6jvMToxyVxJv9gJ412Pt_mYr3c_AkUm3ZgiWs5g=s800-no
Unfortunately soft pine does't take repeated Cleko insertions very well. I ended up grabbing the first part of my Vans practice kit and drilling a hole in the angle to set the caps.
9J0N-o4lWgfgBx-niuK12MsublDgbXb5lKbzAYaBX3YhCbARrzYX1ClYO4zL-4LM3CZYsF8aPmDeesOd0F4nZky_Ghd7Hng1vQVwFr_1XEwcOjUTgE-I-jTTxjTE5tmVeBUhyfvXJPOzGLmeSURp57Sv5Qu3CnSkpX7ezacvyqoHC4OS8gKbYZEuzNT5JvxDq_7-be17eq5mUz9qgvzhx-3eoqvumeeZ0_vcgp4qy3rjNJDQNHwpPdQW6UIL2ciw-bJLY4pT9vrrfa7FGElChDDDZmQ6rQOAGhTEmtTXb31Bf7RMgOqQBH6luXwjRtew7rPEuPcH7vmnBTcsWzFyKwN_D93G1qqsSYVACPRBR0rED9y8p6vYUUqgJPPn8QKQEGRLdSOGoKS2AfjXuA2G89b_xzpE21hfiECB8DGr4NTWE4v3XYqBP5H7KMwYoNGH8Mu4VdTEKGsrYp9vnDlZQZqm_SicbokV_m1BdzaOyPVFU2_-asCkB8YIuIJIi22xI83bSU54bhafhkF2Ww-tuVPTP9V09tYL1zXA-UOob9jI7WGGx1HhegV5Z08ZvgUMrZE5rQi-hlbTcRS_7RRP2eBBGrokgUpP5oaFOZXjHEVOKHAkDCL1pGicNiaHBZZv3ogheWxvqOIcvzTgMqxmbNbj2VLsfPfbYEA=s800-no
Test fit on a rudder skin. Holds the layers together just fine, but you can feel that it's not as solid a connection as a "naked" Cleko.
4xYd5ZvXwkCWu2vNMmVhx2lus951rMlOXETSIpRX7DEkBeJ_xwmns1eAoF-UzViXCC6o-_cbCySNx574Oua-baTVwWsc-SV1Rzly3DyTW5m1mkPkM9jfiqdNS8Sf9YHUJ-z4iVLzj0lHOR2dJA0nlqzqEK5Np0mwUGuqiYHkk4w-DPb6oQKW6FFpfRzWxmx0NwNEnwjL19a6Eh95SVFvp1u29dxZZ_g9fRxTKLXRQTRQl1jOxnHkgGbwMRWjTywRzizphFDjLOx7E8p5AEkEXPdWuVQNQKxqqa6lnhlC1RAwZhbnWN3gAUQjtzMK9-3Pt2AtfqOfhshPYcwWCn5ImfP2e8kyeh5JW-1e1x3_asCMcabfMqaJ1meW_3l3SLCQBJRxGCJzMrCgBBo92L0BfrioL2bhr8ECpn4Ayy3zkUuhCvou6tZ5Dziif4h8THuZNRUdPAc5lhk-zVuSjTpdObEqPC2-hLSYtdTRclrRr5cAw5Upd8rW7G0mQ3weswA882Q63FLdby5nM3PY-1SertlKc4KGQ_f9gD5UW084mn8qSE-U6jnfxKbwTZnij-dxnkLUsZIoJf45EYGAzEdrhnCnfNjaoIj_FhA4fi_aSYiA57nSyEYE98ApPJ7mliNtmPd0faGGD6jftEOcXA4U8hh6FeKYf1pjF9M=s800-no
End result?!?...
I can now make capped Clekos on demand for $0.04 a pop!
P_U4gxVHvILKubjk_Ef-qf7YiPTG8RaN8U0iIRru8FVNP3kdgR8T2wu79V_5BAP59Zlo0HU7If4Ffj5kxBVxnRsn4YpHZjV_T4SYvM93TF7TwPrufWbHAJWM1oIe3wqnJ2iUJ5V2qXNaqg9rIimfEqpiU1jS0cRr7UsGtBYEg2cVqtY1HSIu2-BwNasAH3NrUYVahwGjMPILPSu4OC5dLWk0sCGTjYp0qh9WwpLsredVCBskeZncGq0uI3bHFl2O2UhdtcvtWqooalU6X7pgiBxuTFjIUfdZe7laG9bMEXvv648Cdog27VxCnVDDwDFMqqt8l_Mf5028yaDbz7Yc2_am197kypr9Qkruez0ZccHFmQ2rSr82o35iQQqQaqEjAh3FC-4JZGuHy7sgczWuoe6kUrUp9PylPftdjdcs8EK9Vg_a-z_DzybZCnp69VT9G2-R9rLCXp3nwcA20hK5UnOBHMrV5c7noFvoDWAqeDCuH2VRH8jWNUYH7-ezzolt49kLQwkWVYu3lwu2CBZIMTfqmcVc8zwcQJrbt3RGehPySdm7oWW9BcijjY9bWkUohRD7fNuSZjkpsPS1FhfSWLwV1WCessPWroYMaxbUfi8vEw9P_tv0vxhRb2mWppZBHlm9pEf_d6FPzCy4bPo6KsXIdC9HDTivK6o=s800-no
