Old 03-13-2019, 05:14 PM
E. D. Eliot E. D. Eliot is offline
Default Additional elect power?
I'm training on a Sling so I'm around their shop some. They are constantly building up new Slings to sell. Saw one which had a Rotax? alternator attached to the upper left hand area of the engine PSU. Bolts right on - I think that it is a 15 amp alternator. Looks like a very clean installation and I guessing - that that alternator was created or blessed by Rotax.
So, i'm interested to know if anyone has installed such an alternator to his/her RV-12 after certification? The cowling of the Sling is longer so, to install this type of alternator on my 12 would require considerable cowling rework. Probably need to add 4-5 inches to the front of the cowling. And add a prop spacer alike the one on the Sling. I'm a few months or a year from doing this so I have a while to gather opinions and facts. Your thoughts - Thanks, Ed
Building finally
Old 03-13-2019, 06:14 PM
Dvalcik's Avatar
Dvalcik Dvalcik is offline
http://www.vansairforce.com/communit...ad.php?t=85230
An old post from a few years ago
David
EAA 1434 KBST
Belfast, ME
david@rv12pilot.com
2019 VAF Supporter
RV12 #568 EAB
* Started 9/30/2011
* 1st flight 8/30/12
http://www.rv12pilot.com
Old 03-13-2019, 07:35 PM
alexe alexe is offline
There is also an alternator that can be mounted to the rear of the gear reduction unit. I believe that the vacuum pump mounting pad is used for the purpose. That would (probably) not require a cowling extension, however the pitot tube would have to be relocated elsewhere (like the wing). You might want to check that out.
Alex Erdelyi
RV-12 #120758, N912AE
Flying as of 4/28/15
Paid through December, 2019
Old 03-13-2019, 09:09 PM
Mark33's Avatar
Mark33 Mark33 is offline
You might want to check out Edge Performance. They have one that mounts to the back of the engine. https://shop.edgeperformance.no/en/h...lternator.html
