Old 02-27-2019, 07:57 PM
AlanTN AlanTN is offline
Default Updated Range Numbers
In August of 2017 I started a thread with questions about the RV-12/RV-12iS range numbers. One of the questions I asked was how with the RV-12iS at 5500 RPM and 7500 ft, the range could be 630 miles, while at 5000 RPM and 7500 ft, it was only 605 miles. It just didn't seem likely to me that at a higher speed the range would be farther. Those numbers still exist in the current RV-12/RV-12iS brochure on Van's website should anyone wish to verify that.
However, I see that they have now posted in the performance section on the webpage some new numbers that make much more sense to my engineering mind. They are as follows: At 5500 RPM and 7500 ft the range is listed as 528 miles, and at 5500 RPM and 7500 ft the range is listed as 631 miles.
These new numbers are in line with what I would expect, and I am pleased to see the update. As I stated before, I am very impressed the the current design of the RV-12iS and with the quality of Van's aircraft kits.
Alan Bishop
Mechanical Engineer
PPL since '66
Old 02-27-2019, 08:17 PM
rongawer rongawer is offline
The 528 and 631 numbers agree with the 459nm and 549nm ranges listed in the updated POH. It’s important to note that both of these ranges are listed as “no reserve”.
I was a little disappointed to not see the ranges even longer as has been described in other threads, upwards of 30% stated by some. And that the listed 5500 rpm range for the ULS is longer than for the iS; both are no reserve numbers, so I’m interested to know if that’s accurate.
Ron Gawer
- RV10, Build in progress.
- RV12, N975G, "The Commuter"
- Several others that are now just great memories for me.
Old 02-27-2019, 09:56 PM
Originally Posted by rongawer View Post
The 528 and 631 numbers agree with the 459nm and 549nm ranges listed in the updated POH. Itís important to note that both of these ranges are listed as ďno reserveĒ.
I was a little disappointed to not see the ranges even longer as has been described in other threads, upwards of 30% stated by some. And that the listed 5500 rpm range for the ULS is longer than for the iS; both are no reserve numbers, so Iím interested to know if thatís accurate.
I think you misread the ULS #'s.......
The 5500 RPM range for the ULS is 433 sm, which is far less than the 528 sm listed for the iS.
Scott McDaniels
Hubbard, Oregon
Old 02-28-2019, 08:25 AM
No, I didn't misread it. POH revision 3, section 1.2 clearly shows "nm" after the ranges listed along with an asterisk noting "No allowance for takeoff, climb, descent or reserve".
If that is an editing error, ok. You might go check it, however both the ULS and iS ranges are listed as 'nm'.
Ron Gawer
Old 02-28-2019, 08:32 AM
Ok, it was I that read incorrectly. I didn't see that you said POH
The numbers that I posted (ULS is 433 sm, and iS is 528 sm)are what are on the web site and I believe they are correct.
Scott McDaniels
Hubbard, Oregon
Old 02-28-2019, 11:50 AM
So, in the interest of brevity, are we talking in nautical miles or statute miles, for both the ULS and IS motor versions, on the webpage. Which unit of measure is correct?
Old 02-28-2019, 12:22 PM
The current range numbers on Van's website appear to consistently be shown in statute miles.
The new numbers for the RV-12iS make sense to me.
But, what still mystifies me is how the range of the standard RV-12 could be nearly the same at 120 mph (435 miles) as at 136 mph (433 miles). That doesn't seem likely considering that drag increases as the square of velocity.
Another point is that if you compare 435 miles for the RV-12 and 631 miles for the RV-12iS, both at 7500 ft and 5000 rpm, the range of the RV-12iS would be 45% longer (631/435-1)*100 = 45%.
Based upon tests done by Rotax, I think 30% improvement is likely, but not 45%. Because this is larger than normal experimental error of perhaps 2%, one or both of these numbers may be suspect.
Disclaimer: This is only my opinion and of course I could be mistaken!
Alan Bishop
Mechanical Engineer
PPL since '66
Old 02-28-2019, 03:32 PM
Typos are not mystery's, they are caused by less than perfect humans.
I imagine there is still one (if not more) in the RV-12 data so it will be looked at.
Scott McDaniels
Hubbard, Oregon
Old 02-28-2019, 03:34 PM
All of the range distance values on the web site have sm after them so the intent is for them to be Statute Miles.
Scott McDaniels
Hubbard, Oregon
Old 02-28-2019, 04:19 PM
Thanks, Scott. That was what I was hoping for.
Alan Bishop
Mechanical Engineer
PPL since '66
