Old 02-20-2019, 07:56 PM
DHeal DHeal is offline
Default Running Mods for Bing Carbs at SI-912-032
Hot off the press: https://legacy.rotaxowner.com/si_tb_...si-912-032.pdf
EAA #23982 (circa 1965) - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B) - N124DH flying since March 2014 - 740+ hours (as of Mar 2019)!
VAF donation through June 2019.
Old 02-21-2019, 12:27 AM
Guaranteed not to sink?
Here we go again...
Hinckley, Ohio (1OA2)
EAA #499867
80 hrs Flying Aeronca Chief 11AC N68203
RV-12 Bought Flying Oct 2015 with 48TT - Hobbs now 415
LSRM-A Certificate 2016
Special Thanks to EJ Trucks
Old 02-21-2019, 05:56 AM
AirHound AirHound is offline
Hopefully Available to the masses initially at a good faith discount.
Doug
Old 02-21-2019, 10:41 AM
Maybe you can return your old ones for credit? Or just get the MS brand that are blue and sealed in epoxy, since epoxy is pretty much inert to everything.
Old 02-21-2019, 11:03 AM
I got some of those blue ones and they were a tad overweight out of the box. Sadly, returned them. Dang!
Just advised by parts store that 189's are not available on their shelves yet, however, for all intents and purposes, they are same as 188's except for who made them...and different ID mark.
Anybody out there happy with the blue ones???
Doug
Old 02-21-2019, 12:13 PM
How much is a tad overweight?
EAA #499867
Old 02-21-2019, 12:53 PM
Driftdown Driftdown is offline
Yeah . . . like a direct exchange.
Old 02-21-2019, 05:25 PM
Sorry the numbers escape me, but between 7 and 8 per pair.
Doug
Old 02-21-2019, 05:58 PM
mdoyle mdoyle is offline
I purchased and installed a pair of the Marvel Schebler floats. Weight out of the box was: 3.7 and 3.8 grams.
Mike Doyle
RV-12
RV-9A, Under Construction
Xenia, OH 45385
Old 02-21-2019, 09:08 PM
N456TS N456TS is offline
I would not assume that the Rotax test for floats applies to the MS80-430 floats. They're different floats. The only thing that matter is if the horizontal float pins align at the same location when the bowl has fuel in it. Weighting them using the specs of a foam float is in the realm of - my Chevy uses this spec, so I'll assume the Honda does too. In the case, the testing method will work for both float styles, however, the weight specs should be different between the different designs. I'll be ordering a set of MS80-430 soon, as I suspect I'll be forced to change floats again...
