Old 02-14-2019, 05:21 PM
08FATBOY 08FATBOY is offline
Default AOA wing removal
My current 12 was built as an E-LSA by synergy. My concern isn't with wing removal iself but with the wing root fitting. Does the wing just pull off or do you have to release the fitting. 1st condition inspection is due, afterwords does the system need to be re calibrated
Old 02-15-2019, 12:40 AM
redbaron redbaron is offline
Red face Quick release
Van,s makes a quick release kit which works great and can be installed when the wing is off.
Old 02-15-2019, 05:35 AM
AirHound AirHound is offline
Trying to keep up with the times. What does the quick release do specifically that the standard wing release mechanism doesn’t? How simple or complex is the mod to install this quick release? Thank you for any insight?
Doug
Old 02-15-2019, 05:37 AM
DaleB's Avatar
DaleB DaleB is offline
When I installed AOA in mine before Van's came out with their retrofit, I used quarter-turn quick connect fittings. Since removing the wing is a two-person job anyway, the person at the wing root gets to disconnect and reconnect the fitting. No big deal. The Van's hookup does it automatically. And no, there is no recalibration needed.
Dale
Omaha, NE
Previous RV-7 project (sold)
Old 02-15-2019, 08:15 AM
DHeal DHeal is offline
Airhound -- https://www.vansaircraft.com/service.../n-2016-12-14/ -- for "AOA Quick-Release" info.
EAA #23982 (circa 1965) - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B 2020) - N124DH flying since March 2014 - 800+ hours (as of Aug 2019)!
VAF donation through June 2020.
Old 02-15-2019, 06:05 PM
Thank you dheal!
Doug
