  #41
Old 02-17-2019, 08:13 AM
No, if you're building experimental airplane, then only Annual Condition Inspection is required. 100 hour inspection is not required.
Also, if you're building your RV-12 as E-LSA (not EAB), then you are permitted to do your own condition inspection if you take 16 hour training class and apply to FAA for rating which is good only for the plane you own.
Hinckley, Ohio (1OA2)
EAA #499867
80 hrs Flying Aeronca Chief 11AC N68203
RV-12 Bought Flying Oct 2015 with 48TT - Hobbs now 415
LSRM-A Certificate 2016
Special Thanks to EJ Trucks
Old 02-17-2019, 08:25 AM
DaleB's Avatar
DaleB DaleB is offline
BTW, on the subject of oil... I pulled up my Blackstone Labs report from our oil sample after the first 100-hour oil change cycle. I'd been changing it at 50 hours up until the last one. Coincidentally and conveniently, we flew almost exactly 100 hours in between condition inspections. And again, we very, very rarely burn any leaded gas, maybe 20-50 gallons a year.
Metals are in great shape for such a long run, and iron is fine at 75 ppm (it's wear rate per-hour is quite low, indicating good wear at steel parts).
The viscosity numbers are fine, as is the flashpoint and every other number I see on the report. I was very happy to see the report, and will continue to have Blackstone do the oil analysis at every oil change.
Dale
Omaha, NE
Previous RV-7 project (sold)
Old 02-17-2019, 09:01 AM
Dale
Just for a data point... do you preheat engine in the winter?
EAA #499867
Old 02-17-2019, 09:47 AM
RVbySDI's Avatar
RVbySDI RVbySDI is offline
The first statement about Anual Condition Inspection and 100 hour not required is correct. Some added clarification on your second statement about E-LSA and EAB.
  • If one builds an airplane and certifies it as an E-LSA, one can "take a 16 hour training class and apply to FAA for rating which is good only for the plane you own".
  • If one builds an aircraft as an EAB one can apply for the Repairman Certificate for that aircraft. With that Repairman Certificate that builder can sign any and all airworthy inspections on that aircraft. She or he does not have to take a training course in order to receive the Repairman Certificate.
RVBYSDI
Steve
RV9A
https://rvwings.com
Live Long And Prosper! 🖖🏻
Old 02-17-2019, 10:17 AM
The importance of doing the 100 hr inspection regardless of whether your certification requires it, is for maintaining and inspecting in accordance with Rotax's written requirements for factory warranty.
It is also a good guide for doing an annual condition inspection even if you don't reach 100 hrs in a year.
Scott McDaniels
Hubbard, Oregon
Old 02-17-2019, 01:00 PM
DaleB's Avatar
Dale
I live in Nebraska. The engine heater gets plugged in in November, and stays that way until March or April. Yes, we preheat, with extreme prejudice.
Dale
Omaha, NE
Old 02-17-2019, 01:36 PM
NORM T NORM T is offline
Default Operating cost comparison, RV-9, RV-12
Was this thread about "my old man can beat your old man", "my airplane is better than your airplane", "a comparison of mission", or what? My RV-12 is the very best for me, but I would like your choice, too if it suited my purposes!
Norm
