Old 02-14-2019, 11:16 AM
bruceh's Avatar
bruceh bruceh is offline
Here is my experience with 640+ hours so far on my RV-9A with a Lycoming IO-320.
My fuel cost per hour over the last 5 years (tracked in a spreadsheet, since I'm a computer geek) has been $26.75. I use around 6 gallons per hour of 100LL in my flying. Never tried autogas, since everything in California has ethanol.
I do an oil and filter change 4 times a year. This costs me about $300 per year, includes getting the oil analyzed.
The only other "maintenance" costs I've incurred have been tires and brakes.
At various times for annuals I have replaced little things like the crank seal on the engine (finally got it to stop leaking oil), touched up paint, and done some electronic upgrades (fix flakey EGT probes, replace the ELT battery, new 2020 GPS, knob panel for the Dynon Skyview). The P-mags use automotive spark plugs and that costs me $24 per annual to replace all 8 of them.
This year my annual is coming up on 5 years, so I will be taking a look at possibly replacing my alternator belt. I think the hoses are good for longer than 5 years.
So I'm 1/3 of the way to TBO, and hopefully this trend will continue. When it comes time to overhaul, I may just swap an IO-360 in her.
Bruce Hill
RV-9A N5771H flown over 600 hours!
2018 VAF donator
EAA Tech Counselor
Old 02-14-2019, 12:01 PM
Flynfrfun Flynfrfun is offline
Originally Posted by DaleB View Post
Nope. One-time $700 hit for a complete set of new Teflon fuel hoses, good until overhaul.
That is true DaleB...this is a recent update that should reduce Rotax ownership costs.
I've been interested in purchasing an RV12 and have had the chance to look thru several engine log books. What I see is a lot of money being spent on service bulletins, 5yr rubber changes, carb overhauls, gear box maintenance, fuel pumps etc.
Personally, I can't enjoy 8gal/hr ($45/hr) Avgas cost in my flying which is why I've been looking at RV12's.
Josh
Old 02-14-2019, 12:03 PM
JwWright57 JwWright57 is offline
Besides maintenance costs there is a usability factor to consider. The Rv-12is is almost car simple, no mixture control (and Fi on on 12is) so no carbs to worry about, just go fly. And the biggest thing for me is that you can build one by yourself (don't really need a second bucking bar buddy) and really quick. I was going the 9 route but figured I could build a 12 years quicker. :-) I can go along way in the year/year and a half while a 9 builder is still pounding rivets.
Jeff Wright, Charlotte NC
Rv-12 started!
Tail 99% done
Wings 99% done
12IS fuse kit in progress
Dues paid 2019
Old 02-14-2019, 12:12 PM
Bruce, which 9-A was yours at Copper State Fly Inn? N938BL and I were there on Friday in a RV-12. I saw several of them there, one a newly completed 9-A all painted up in yellow, for sale, 50 hrs on it, all steam gauges.
Old 02-14-2019, 12:40 PM
scottmillhouse's Avatar
scottmillhouse scottmillhouse is offline
Default Built and flew both
My opinion: Built a 9A and flew it 536 hours and now about 350 hours for a 12. I'd say if you can do it all yourself, maintenance costs are probably slightly less for the Lycoming. Everything costs more for the Rotax than it should since you can only buy from Rotax. As an example the float issue is ridiculous at $80 per float with four required.
Fuel burn is less and you can use auto gas but appropriate alcohol free fuel is almost the price of avgas and you have to buy avgas on x-countries. If you use the same fuel than economy is about the same. The 12 uses about 30% less fuel in cruise than a Lycoming but it is about 30% slower. I had to sell my 9 due to medical issues and switch to LSA until I got a special issuance. Now I'm finishing up on a new 7A. Once you had a traditional RV, a LSA just is not the same.
So visibility and entry + to the RV-12. Probably the best LSA you can get, but it is a LSA. Speed, climb performance, baggage and people capacity and a constant speed prop to the Lycoming powered RVs. Slight differences in maintenance and fuel cost an hour for your dream should not be an issue when you are already investing in the vicinity of $100k or more for a new bird.
Scott- 2019 dues paid
Got medical back, now building a 7A; N579RV almost ready for finish painting.
RV-12 #120515, N319RV 1st flight 12/2015 now over 280 hours.
RV-9A, 536 hours sold, RV-7 sold, Kitfox sold
Old 02-14-2019, 01:21 PM
DaleB's Avatar
DaleB DaleB is offline
Yeah, that. If you are limited to LSA, then the RV-12 is, in my humble opinion, absolutely the way to go. If I could legally fly a 7 or a 9, I would be doing so. No question, hands down, period. Just to be flying 30-40-50 knots faster and making fewer fuel stops on cross country trips. Maintenance cost may be a little higher, may be a little lower, but the -12 is so much different from the others that the slight difference is not enough to be anything even remotely close to a deciding factor.
Dale
Omaha, NE
Previous RV-7 project (sold)
Old 02-14-2019, 02:54 PM
Not sure I agree with the comment on the Rotax being car simple. It has it's own unique issues. The Lycoming is 1950s simple. If run frequently you have only 500 hours maintenance on mags and plugs and you may have some valve issues to deal with around TBO. Generally that is about it and over 50 year old engines are still being rebuilt multiple times.
The Rotax is a great little engine but it is maintenance intensive compared to a modern car. The ULS has carb issues that are problematic, besides floats sinking every few hundred hours you need a rebuild at 500 hours and a carb syn at least every annual, fuel pump issues, gearbox maintenance, hose replacement, lead buildup when using avgas and it you blow any electronics it could cost thousands and lots of down time to get parts. A plus is spark plugs are dirt cheap and it only holds 3 quarts of oil (but oil is $10 a quart). The fuel injected engine eliminates the carb issues but at a price.
On the plane construction the 12 is so simple to assemble by yourself that you will be flying and enjoying a RV years quicker. RV-9A slow build took me 7 years and 2500 hours, the 12, 15 months and 1000 hours. Looks like the 7A Quick build plus will be about 18 months and 1400 hours but I'm now retired.
Once to altitude the 12 is just as much fun to fly as a 9 and maybe more in quick maneuvers with it's helicopter like visibility. Same crisp handling and response. I'd say roll and stick responsiveness is identical.
Old 02-14-2019, 03:11 PM
romaja romaja is offline
Originally Posted by airguy View Post
Yep, you said it. I am burning autofuel as well, and you can't do this in a 12. Midland, TX to Hot Springs, AR in 2:38 last weekend.
Impressive economy/MPG's!
I have been burning autogas in my Rotax 912 and have been loving the economy. Also, no lead buildup and can go longer between oil changes (50 hours instead of 25).
Jim
_________________
Jim Roman
Retired Airline
Rans S20 Raven Built 2016 (Repairman Certificate)
Vancouver, Washington
ATP, CFI, II, MEI
Old 02-14-2019, 03:23 PM
DaleB's Avatar
Jim
Read the manuals again...
No avgas == 100 hours
30% or more avgas == 50 hours
Over 50% avgas == 25 hours
The SI is less than clear about this, but the maintenance manual clearly shows an oil & filter change as a 100 hour item. Asked about it at the big Rotax tent in Oshkosh a couple of years ago, and they confirmed... for a 912ULS running mogas, it's 100 hours. Of course like with any other engine, if you change it more often than that you're not going to hurt anything.
Dale
Omaha, NE
Old 02-14-2019, 03:33 PM
Three liters per oil change and almost zero replenishment in 100 hours.
Try not adding oil to a Lycoming...
Hinckley, Ohio (1OA2)
EAA #499867
80 hrs Flying Aeronca Chief 11AC N68203
RV-12 Bought Flying Oct 2015 with 48TT - Hobbs now 415
LSRM-A Certificate 2016
Special Thanks to EJ Trucks
