Old 02-13-2019, 10:01 AM
Default Maintenance costs RV-9A vs RV-12
Bigger motor, a little faster, sucks more fuel. Less efficient for flying around the patch, payload is about the same... What am I missing about comparison of operating costs and insurance? I see many RV-9A's for sale, with steam gauges... Cost to upgrade to glass like a Dynon D1000 touch or ?
Old 02-13-2019, 10:53 AM
YellowJacket RV9 YellowJacket RV9 is offline
I would say that 50mph is more than "a little faster". 100 lbs vs 75 for baggage is also not insignificant. Not sure about comparing operating costs as I have never owned a Rotax but the costs for my O-320 are very reasonable, and parts are easy to find almost anywhere.
For trips around the patch and local flying, a 12 is perfectly suited, and even the occasional XC. More frequent or longer XC's would certainly favor the 9.
Panel upgrade costs depend on who does the work. If it's you, its the cost of the avionics, new panel, etc. If you hire it out, you can probably double that, if not more.
Chris
Chris Johnson
RV-9A - Done(ish) 4/5/16! Flying 4/7/16
Old 02-13-2019, 11:20 AM
Zuldarin's Avatar
Zuldarin Zuldarin is offline
Hah, when I fly side by side with my Rv12 friend I’m burning about the same amount of fuel....but I can go much faster, higher and carry more in my 9A. The only different is I am usually burning 100L and he is burning auto fuel.
Darin
Snoqualmie WA
RV-9A Flying as of 03/2015
RV-10 Building - Fuselage
www.DarinAnderson.com
2018 donation sent!
Old 02-13-2019, 11:49 AM
rv7boy's Avatar
rv7boy rv7boy is offline
Forum Peruser
Originally Posted by Zuldarin View Post
...I am usually burning 100LL and he is burning auto fuel.
And in some places, as on a cross country, auto fuel (mogas) is hard to find without going into town. Update: All I was saying was that if the "other guy" in that post is burning auto gas, he might have to be careful where he lands on a cross country if he wants to continue to use mogas. Hey, I'm a fan of the 12.
Don Hull
RV-7 Wings
KDCU Pryor Field
Pilots'n Paws Pilot
N79599/APRS Automatic Position Reporting System
“Certainly, travel is more than the seeing of sights;
it is a change that goes on, deep and permanent, in the ideas of living." Miriam Beard
"It should be added that the sublime beauty of the facture brings within the realm of discourse the substructure of critical thinking. " -using Doug's Art Critique jargon link and my birthday, I get this!
Old 02-13-2019, 12:36 PM
DaleB's Avatar
DaleB DaleB is offline
Bear in mind, the RV-12 does not require MOGAS. It is optional. Burning AVGAS some of the time, or even all of the time, will affect maintenance frequency and cost, but it's not a problem. There are RV-12s being operated on 100% AVGAS.
I like the RV-12. It's a fine airplane, within its design limits. If it fits your requirements, it's a great little airplane. Having said that, if I were not limited to flying with Sport Pilot privileges, OR if those privileges extended to the RV-9, I would almost certainly be flying an RV-9. The RV-12 has better visibility, at least downward. The RV-9 has more speed, more baggage space (never mind weight capacity), and is a little more rugged. And you can put an engine in it that can burn MOGAS if that's a factor for you.
Dale
Omaha, NE
Previous RV-7 project (sold)
Old 02-13-2019, 12:53 PM
airguy's Avatar
airguy airguy is offline
Yep, you said it. I am burning autofuel as well, and you can't do this in a 12. Midland, TX to Hot Springs, AR in 2:38 last weekend.
Greg Niehues - PPSEL, IFR, Repairman Cert.
Garden City, TX VAF 2019 dues paid
N16GN flying 380hrs and counting! Built an off-plan 9A with too much fuel and too much HP. Should drop dead any minute now.
Old 02-13-2019, 01:05 PM
That's a tailwind of 56 kts... gettin a little help there, headed 054, gonna pay for it when you head back home. How much motor and HP are you running in your bird?
Old 02-13-2019, 01:10 PM
airguy's Avatar
You asked about the difference between the airplanes, not about headwinds and tailwinds. I'm getting better than 22 nm/gal TRUE in that photo at 149 knots true, at 17,000'. That's what my 9A can do, and I still have a ton of drag cleanup to complete.
The two planes are not the same - they each have niche to fill. Different pilots have different missions. Pick the plane that fits your mission and fly it.
krw5927 krw5927 is offline
Coming from an RV-9A owner who just took his first RV-12 ride yesterday, this is definitely true. The additional visibility afforded by the 12 is very nice.
Kurt W.
RV9A
FLYING!!!
Old 02-13-2019, 02:18 PM
snoop9erdog snoop9erdog is offline
Default 17K
Apparently the Roncz airfoil wing likes 17,000 feet. Nice!
Ed Avila
St. Johns, AZ (SJN)
N646A RV9
Worlds longest RV build...but getting there
