Old 12-30-2018, 03:26 PM
bobg56 bobg56 is offline
Default Garmin GDL 82 ADS-B
I'm trying to figure out what kind of device to get for my 2010 RV12, either the GDL 82 or Sky Beacon, the GDL 82 antenna placement has me concerned. I would like to place it under the engine cowl next to my GPS antenna that would be easier but would it create problems? Or the Sky Beacon, has anyone put these on their RV 12's? ...The Sky Beacon seems the simplest but simple sometimes has issues, I can use some advice...thanks.
Old 12-30-2018, 04:24 PM
See... http://www.vansairforce.com/communit...&postcount=101
No problems installing two GPS antennas next to each other under fiberglass cowling.
Hinckley, Ohio (1OA2)
EAA #499867
RV-12 Bought Flying Oct 2015 with 48TT - Hobbs now 480
LSRM-A Certificate 2016
MJ Stricker (Father & CFI) - 1st Lt. Captain B-17H
Old 12-30-2018, 06:24 PM
philrisl philrisl is offline
I recently installed Uavionix Skyfi-EXT in a friends RV6. Installed the GPS on the turtle deck and spike on the belly. Works great and in in and out. Passes the FAA test.
You may find a difference in the required GPS reception for ADSB versus navigation requirements.
Old 12-31-2018, 07:16 AM
Tankerpilot75 Tankerpilot75 is offline
Yep, no problem at all. I have three Garmin gps antennas under my fiberglass cowling. One WAAS and two non-WAAS. Havenít noticed any issues.
Jim Harris, RV7A, 2nd owner, N523RM
IO-360, Hartzel CS prop, Older Aerotronics built panel Dual GRT Horizon WS, GRT EIS, Garmin 340, 335, Dual 430s, TruTrak 385 A/P with auto level, FlightBox hard wired to WS, Dynon D10A with internal battery (backup EFIS), 406 MHz ELT.
Retired - Living the dream - And going broke!
Old 12-31-2018, 07:19 AM
Now to figure out what to buy that will work the best and easy to install...
Old 12-31-2018, 08:01 AM
snopercod's Avatar
In the RV-12, I agree that the turtle deck would be the theoretically-best place for the GPS antenna due to the large ground plane. Unfortunately, the installation seems problematic. To gain access, I understand you have to remove the gas tank and the rear bulkhead. My RV-12 buddy is contemplating installing a GDL-82 and really doesn't want the installation to become a major project. The next best option (electrically speaking) would be on top of the deck in front of the canopy. It might be visually offensive in that location, though. Although it violates all the guidelines from Garmin, I guess I'll advise him to put the antenna in the engine compartment like others have done successfully.
Regarding the spike antenna - since you will be broadcasting on both 978 MHz and 1090 MHz you will have better performance with a broadband "blade" antenna like the Comant or Delta Pop. Both are available from ACS.
(2019 dues paid)
Old 01-09-2019, 03:59 PM
I purchased the GDL-82 with GPS kit, no instruction manual or coax cable included. I did see the instructions for the Mooney install, should I use these instructions? and what about the cable length for the GPS antenna, is there a minimum length?...I thought the kit would have all instructions and needed cable, a little disappointed but I can get the cables made that I need...anyone who has already put one of these in your RV12, I sure could use your help...thanks, Bob
Old 01-09-2019, 04:18 PM
ArlingtonRV ArlingtonRV is offline
This is the install manual I used.
https://m.aircraftspruce.com/catalog...l82install.pdf
I ordered my unit from Stein Air since I knew I would have a lot of questions and they were very good about answering them for me. Based on information from Stein, the coax should be RG400 and between the GPS antenna and the GDL-82 should be 6.5 feet minimum. The run from the transponder to the transponder antenna should also be 6.5 feet minimum. The run from the GDL-82 to the transponder is not length limited and can be any length. Any excess cable can just be coiled up and secured wherever it is convenient.
Steve Rush
Arlington, WA
ArlingtonRV on YouTube
RV-8 (Bought Flying)
Glasair Sportsman (Sold)
RV-8 Tail, QB Fuselage (Sold)
RV-4 (Bought Flying) (Sold)
RV-9 Tail
RV-12 120018 Flying (Sold)
RV-7 Tail, Wings, Started Fuse (Sold)
Old 01-09-2019, 04:53 PM
jdiehl jdiehl is offline
Default Minimum length of RG400
Would sure like to verify that the RG400 cable must be minimum 6.5í. Iím planning minimum distances between the GDL82 unit and the 1) existing transponder antenna currently between the main gear and 2) the newly installed gps antenna which I anticipate placing on the tip up glare shield. Both of these coax runs will be much less than 6.5í. Is coiling the coax to achieve 6.5í necessary?
Jim Diehl 7A
Lock Haven, Pa
Old 01-09-2019, 05:06 PM
I'm looking at placing the unit inside the forward area where all the other avionics is located, close to the transponder, that will be a shorter cable, but I'll have to coil the 6.5', then mount the GPS antenna under the engine cowl next to the GPS nav antenna..other guys have said that works.
