Old 01-28-2019, 11:32 PM
pilotyoung pilotyoung is offline
Default Vibration
Has anyone with an RV-12 had to have the gear box repaired? I have about 450 hours now and after doing extensive trouble shooting the vibration still exists. A couple of people have said the problem is in the bear box. So I am wondering if anyone else has had gear box problems on the original RV-12 with about 450 hours on it.
Thanks.
John D. Young, RV-12 Owner
Serial Number 120022, N6812Y
Bought it as a flying airplane in Feb. 2018
Just passed 140 hours flight time in RV-12, and 10,000 hours mostly in corporate jets. I am a CFI; CFII; MEI; and a advancd Ground Instructor, CFIG; and hoping to be able to help new RV-12 owners by doing some transition training for new builders and owners in RV-12's.
Old 01-29-2019, 09:43 AM
The gearbox, it's shims, Bellvue washers and the dogs can and do wear on the Rotax 912. Rotax has recommended higher speeds of 2500 rpm for warmup procedure, to lessen the chance of the prop slapping the dogs back and forth when there is near zero thrust on the prop. ie, you should be taxiing at that speed also, and be on the brakes to check your taxi speed. Brake pads are cheap.
I believe the guy that teaches with Sling 2's in the Carson City, NV area has had the same problem with his Rotax gearboxes, his name is Paul... Maybe check on the Rotax forum for this problem?
Old 01-29-2019, 10:05 AM
Phantom30's Avatar
Phantom30 Phantom30 is offline
Originally Posted by NinerBikes View Post
The gearbox, it's shims, and the dogs can and do wear on the Rotax 912. Rotax has recommended higher speeds of 2500 rpm for warmup procedure, to lessen the chance of the prop slapping the dogs back and forth when there is near zero thrust on the prop?
Along with NinetBikes comments....you bought your a/c with 300+ hours. If run @ lower idle speeds for ??? Times....this could account for wear.
Ric Dickison
307 (CAB) Phantom
Search and Destroy (Can
Tho RVN)
Distinguished Flying Cross Society Member
CH-47 & UH-1H "Driver"
Rotax 9 Series Service IRMT
RV-12 Kit#729 "N312RD" is now a full functioning fun machine!! Thanks Van for fulfilling my dream😎
2018 Dues Paid
Old 01-29-2019, 10:27 AM
Default Engine Vibration
I have run the idle above 2,000 towards the top of the green arch on the tach when the engine is cold every since I bought it. The prior owner or his mechanic told me about the slow idle problem so I have avoided it.
Old 01-29-2019, 02:54 PM
Have it pulled and inspected, before you rule it out. Learn how to check end play and side to side play on it. There are some type of thrust washers on it that it's common for them to go out in 100 to 600 or 800 hrs and the lash values get too large..
Old 01-29-2019, 03:34 PM
Dave12 Dave12 is offline
Scroll down the Rv12 threads to Rotax uls912 vibrations solved.
Wag Aero Sport Trainer sold and wrecked
N588DF RV12 #336 Sold, alive and well in New York
N73DF RV12 #244 Sold, alive and well in Florida
N91 RV RV9 I wish I could say I built this one! Mark Santoleri hit the ball out of the park on this gem.
Old 01-29-2019, 05:17 PM
jcaplins's Avatar
jcaplins jcaplins is offline
Just out of curiosity... how would you describe the vibration?
is it just roughness only at a certain rpm?
Roughness gets more or less noticeable as you move away from that RPM?
Is it a beat freq type vibration (subtle thrumming, like a twin with props out of sync)?
note: I don't have a Rotax, nor can I say anything about your gearbox. I'm just curious.
Jeff Caplins
California
RV7 N76CX
(started: Feb 2002 --> Completed: May 2016)
Old 01-29-2019, 06:46 PM
Default vibration
When I am at cruise speed, 5300-5400 and I reduce power to slow down, about 4600 it starts vibrating and I hear it and it continues to about 3000 rpm.
Both hear and feel it.
Old 01-29-2019, 06:54 PM
sirlegin's Avatar
sirlegin sirlegin is offline
It's probably just rebelling about being an RV13?
Nigel
RV9A-N113SQ
52F
Old 01-30-2019, 06:52 PM
https://www.rotax-owner.com/en/rotax...arbox-problems
