Old 12-06-2018, 10:12 PM
pilotyoung pilotyoung is offline
Default Prop/Engine Vibrations
I purchased my RV-13 last February with 338 hours on it. It now has 432 hours on it. This summer I started noticing that when I reduce power from cruise, around 4400 down to about 3800 I get a vibration. I think it started after I complied with the Service Bulletin on the cracks in the front of the propeller hub. I hear the vibration more that I feel it. Two other pilots who have ridden with me also think it is from the propeller or gear box. The engine runs smoothly at cruise and at idle.
About a month ago I rechecked the front hub for cracks, and found none, and reset the blade angles at 71.4 and 71.3. The vibrations continued. This last week I replaced the soft engine isolators with the new ones from Van's and replaced all the springs on the muffler.
When I flew the aircraft, it still has the vibrations. Today I rechecked the blade angles and they are still 71.4 and 71.3. I checked the torque on the bolts and they are fine. I looked all over the engine for anything loose that could be vibrating and didn't find anything.
The propeller was dynamically balanced at 105 hours.
So I am asking for ideas, suggestions on what might be causing these vibrations. Has anyone else experienced vibrations like this?
Thanks.
John D. Young, RV-12 Owner
Serial Number 120022, N6812Y
Bought it as a flying airplane in Feb. 2018
Just passed 100 hours flight time in RV-12, and 10,000 hours mostly in corporate jets. I am a CFI; CFII; MEI; and a advancd Ground Instructor, CFIG; and hoping to be able to help new RV-12 owners by doing some transition training for new builders and owners in RV-12's.
Old 12-07-2018, 05:30 AM
tomkk's Avatar
tomkk tomkk is offline
Dynamic prop balance? Also, I had a similar problem and I found one of my throttle cables was sticking slightly in mid-throttle range. I rerouted it slightly near the carb and secured it better so it wouldn't move. That worked for me.
Tom
Port Orange, Fl
RV-12 N121TK ELSA #120845; first flight 06/10/2015
RV-12 N918EN ELSA #120995 Eagles Nest Project
SPA Panther N26TK in progress
Old 12-07-2018, 06:15 AM
JBPILOT JBPILOT is offline
Default Hi John --
Which prop hub front did you install - D1 or F ? I understand that you can install the blades 'in' a little from where they should be with the 'F' hub. I think it has been discussed that after the new hub, assuming the blades were installed correctly, there still can be a balance difference. Be sure the blades are in there most outward position, and rebalance it. I did mine, and it helps a bunch.
John Bender
Flying RV-12 - Serial #120036
Paid in May ( 5-4-18 )
Old 12-07-2018, 08:45 AM
Default Vibrations
I just reinstalled the original hub after inspecting it. I am planning on ordering the new style hub and installing it.
Old 12-07-2018, 08:58 AM
alexe alexe is offline
John,
Did you really set the blades at different angles (71.4 and 71.3), or is that a typo in your post?
Alex
Alex Erdelyi
RV-12 #120758, N912AE
Flying as of 4/28/15
Paid through December, 2019
Old 12-07-2018, 09:00 AM
DaleB's Avatar
DaleB DaleB is offline
Why tie difference? Was that just the closest you were able to get them to being the same?
Ha... Alex was faster on the keyboard than I was, I see.
Dale
Omaha, NE
Previous RV-7 project (sold)
Old 12-07-2018, 09:59 AM
Default Vibrations
I set them both to 71.4 and after I got all the bolts finally torqued one was at 71.3 and one at 71.4. Since the tolerance is .2 I left them alone.
Old 12-07-2018, 10:39 AM
rongawer rongawer is offline
Seeing you’ve already balanced the engine, and assuming you haven’t changed the spinner or prop pitch, it could be things like a mis-firing spark plug(s) or carburetor balance.
If you’ve taken the spinner off to inspect - be sure you put it back on in the same orientation. It’s only gram weights that make a difference and the spinner is a very common cause. I’d also look for things like missing washers.
Lastly, do another engine balance and look for 2nd or 3rd level harmonics. It could be something like the alternator - but the most likely is something more innocuous like the spinner or a washer on a spinner screw.
Ron Gawer
- RV10, N1530G (reserved). Build in progress.
- RV12, N975G, "The Commuter"
- Several others that are now just great memories for me.
Old 12-07-2018, 10:57 AM
The carbs on the ULS tend to run the engine a bit on the rich side in the mid throttle range. If you have a float that is just beginning to get a bit heavy and floating a bit lower, it could be causing that carb to be even richer but possibly only show up at mid range throttle settings.
Scott McDaniels
Hubbard, Oregon
Old 12-08-2018, 06:24 PM
Phantom30's Avatar
Phantom30 Phantom30 is offline
Thanks.
I second what Scott has suggested; also, carb sync...it is amazing the difference it makes when done right in overall smoothness of engine performance. Took me numerous attempts before getting the hang of it....and not wanting to start a war on the forum (I disagree with Van’s sync instructions) PM me for phone#; and i’ll share a slick method that has worked on my -12 and many other 912 Rotax equipped a/c. The typical comment i’ve recieved after tuning their engines...i’ve never seen it run so smooth...
Ric Dickison
307 (CAB) Phantom
Search and Destroy (Can
Tho RVN)
Distinguished Flying Cross Society Member
CH-47 & UH-1H "Driver"
Rotax 9 Series Service IRMT
RV-12 Kit#729 "N312RD" is now a full functioning fun machine!! Thanks Van for fulfilling my dream😎
2018 Dues Paid
