Old 01-14-2019, 12:00 PM
rolick22's Avatar
rolick22 rolick22 is offline
Originally Posted by NinerBikes View Post
Is this modification for older RV-12's now standard with the 2 parts added to the RV-12 iS kits during assembly?
Yes the gusset are the same on the original 12 and the 12iS. The part that is different are the way the upper and lower horns are mounted to the spar. Itís a totally different set up using new designed brackets that are riveted instead of bolted.
______________________________________
David Rohrlick
PPSEL, A&P
RV-12iS
Empennage Finished
Wings finished to iS standard
iS Finishing Kit Finished
iS Fuselage Finished (mostly)
iS Engine Kit Finished
iS Avionics Kit in work
Serial#12-0864
N112DR
VAF donation made for 2019
Old 03-09-2019, 11:41 PM
jetset44 jetset44 is offline
Default Misaligned holes?
First-time poster here. I have a pre-iS empennage kit and am installing this service bulletin during the build instead of retrofit. I just clecoed the HS-01231C gussets into place on the HS spar (Step #22) and found the holes in the gusset don't align well with the matching holes on the inboard hinge brackets. Both left and right brackets and top and bottom are all out of alignment similarly. See the attached photos below. Did anyone else have this problem or have any suggestions? Help would be appreciated!
Steve
Old 03-10-2019, 12:21 AM
rv9builder rv9builder is offline
There are two versions of the HS-01231C gusset. It's possible you received the wrong one for your kit. See this thread for more information, especially post #18 and 22. http://www.vansairforce.com/communit...d.php?t=168001
RV-12iS Fuselage
RV-9A Project: Sold
Old 03-10-2019, 07:34 AM
Mich48041 Mich48041 is offline
Steve (Jetset44),
Welcome to VansAirforce
Joe Gores
RV-12 Flying
Old 03-10-2019, 11:58 AM
Thanks for the tip, RV9builder! I searched VAF for info but missed that thread. I didn't realize there were two versions of that gusset, but it appears I have the correct one. Looks like a call to Van's tech support is in order...
Thanks for the welcome, Mich48041! Been lurking here for over a year but just now posted.
