Hi all - can someone give me advice on a regulator for my Rivet puller?
J JwWright57 Well Known Member Sep 18, 2017 #1 Hi all - can someone give me advice on a regulator for my Rivet puller?
mike newall Well Known Member Sponsor Sep 18, 2017 #2 Run it at standard shop pressure 80-90psi. Check the puller for notes on oiling, but normally a couple of drops down the airline each morning is sufficient.
rvbuilder2002 Legacy Member Mentor Sep 18, 2017 #4 Lots of prior discussions in the archives.... Here is a couple http://www.vansairforce.com/community/showthread.php?t=65096&highlight=puller http://www.vansairforce.com/community/showthread.php?t=151388&highlight=pull
mike newall Well Known Member Sponsor Sep 18, 2017 #5 Darn.... Down to the last 500 to pull on our 2 12's...... will try the lower pressure
