Walt
I posted this in an older "wing jack warning" thread but thought it may get lost there, I think this is something the community has been looking for and warranted a new trread.
Richard from Bogert Aviation (maker of the tow bars most of us use) and I have been collaborating on this project and I think we (Richard really) have come up with the ultimate jack pad adapter for the RV. They consist of 2 mating pieces, one for the wing and the other for jack. The best feature is the nice deep swivel balls so there will be no chance of the aircraft slipping off the jack pad.
I think it's a winner!
The adapter will fit up to a 1.25 inch ram and has two set screws to hold it to the ram. The jack pad is 2 inches in diameter and is nicely padded so that it can pick up some of the load against the spar (if your tiedown goes all the way to the skin) but even if it doesn't its still a great feature. The stud is 3/8-16 grade 8 thread. They made the stud long so that you could trim it to the correct length depending on how deeply you tapped your tie downs.
If you're interested in purchasing a pair contact Richard at Bogert Aviation.
[email protected]
[email protected]
