Old 04-14-2013, 01:53 PM
Ron B. Ron B. is offline
Default ADAHRS mount
On page18-03 , step2, says to match drill #30 the W-00012A. My W000012A has a tab type ear 1/4" wide sticking down 3/8" below the flange. This tab is not shown on any of the diagrams in the manual. There is no mention of cutting it off, but I'm guessing it must go.
On same page , figure 3 you can see one hole in the flange just above where W-00012A is labled. The tap I'm refering to would be visible sticking down below the hole in that flange.
The tab in my opinion is preventing the flange on th W-00012A from nesting down in the "J" channel properly in order to match drill.
Just checking with others before cutting it off and regretting it later.
Lastly on page 18-05, figure 2 shows a hole just left of the inspection hole on the bottom inboard skin. I did not see any mention of it's purpose. I'm guessing perhaps outside air temp.?
Thanks Ron
Thanks Ron
RV-10 SOLD
RV-14 Flying
Old 04-15-2013, 05:37 PM
Tried tech. support and had a couple long waits with no luck (Sun & Fun). Sent off an e-mail and hopefully I'll get an answer.
Thanks Ron
RV-10 SOLD
RV-14 Flying
Old 04-15-2013, 07:01 PM
Larco Larco is offline
As I remember it had to be cut off. Larry
Old 04-19-2013, 02:12 PM
Finally got almost half a responce to my questions. Did get, the tab is there for (Van's) bending procedure. The tab makes a straight line on the otherwise tapered flange for the bending press. I had asked if the ADHAR mount was for a Skyview or one of the other vendors?? and did not get a responce to that. I also asked where,this tapered flange (tab removed) would sit on the "J" channel. It's my understanding from installing the ADHARS in our RV-10, that positioning is critical, no responce.
I'll have to leave the mount installation until I have the ADHRS in hand and do the installation myself.
Thanks Ron
RV-10 SOLD
RV-14 Flying
Old 08-08-2013, 07:46 AM
Debovsky's Avatar
Debovsky Debovsky is offline
Perhaps it could be related to that same subject, I'm studying the wings assembly manual and I'm wondering where to install the secondary SkyView ADAHRS Module (the SV-ADAHRS-201 for redundancy). This of course is if you elect to choose a Skyview system.
I don't recall having seen two sets of brackets for this.
Marc R. Beauvais
S/N #140070
50% airframe done
C-FOOT (reserved)
2018 due paid
http://www.mykitlog.com/Debovsky/
" Resistance, is futile "
Old 08-28-2013, 01:34 PM
Aerosporty's Avatar
Aerosporty Aerosporty is offline
Is it just me, or does the rivet callout for the assembly seem all wrong?
Old 08-29-2013, 04:34 PM
3014RV 3014RV is offline
Default 2nd ADAHRS
I've had this same question--if you want two ADAHRS, should you mount the second one adjacent to the first or find a second, completely different location?
Old 08-30-2013, 12:42 AM
jchang10 jchang10 is offline
My plan is to stack one on top of the other on the same tray. I believe Dynon said this was kosher.
#40533 RV-10
1/2006 Started build
10/19/2011 First flight
11/26/2011 Phase 1 Done
12/25/2013 First coast to coaster HAF to K88 to JYO
