Old 01-30-2013, 06:28 PM
Mike Buckler Mike Buckler is offline
Default Dimpling ribs under wing walk doubler ???
I have managed to dimple both top and bottom of all the main wing ribs including under the wing walk doubler's. I have searched the forum and it seems that on other models the builder was given the choice to dimple or machine countersink in doubler area. Does anyone know of a reason that the 14's would be different, or why the doubler area should not be dimpled. I tried dimpling 3 pieces of .025 and they seem to rivet together fine. I contacted Vans and was instructed to just press out the dimples and carry on. I am concerned that if I press out the dimples it may weaken the rib flange's around the rivets. Any comments or suggestions would be appreciated.
Mike
Old 01-30-2013, 06:53 PM
KCBerner's Avatar
KCBerner KCBerner is offline
Default You're not alone
If you read the instructions carefully it does say to dimple just the bottoms first. That's because they are calling for machine countersink on the area of the doublers. But don't feel bad: I did the same thing. Several places here it has been discussed that its ok to un-dimple (or even dimple the other way) once without compromising strength. It sounds like that's what Vans told you too.
I squeezed them out with the hand squeezer. Took 5 minutes.
K.C.
RV-14A #140026
Wings 70%. Started on the Emp.
www.KCandAshleyBerner.com
Happy to be a 2016 =VAF= contributor
Old 01-30-2013, 09:49 PM
mcattell mcattell is offline
Default Ditto
I did it too. I also pressed them out with the squeezer and moved on. Not a big deal. How soon I forgot after building the -9A how important it is to read those instructions very carefully.
Mark - Forest Grove, OR (Homebase KHIO)
Flying RV-9A N962MC
EAA Tech Advisor - Ham AI7MC
Old 01-31-2013, 10:39 PM
Mike
Old 07-06-2013, 10:29 AM
LAMPSguy's Avatar
LAMPSguy LAMPSguy is offline
Default Dimpling
On page 12-02, step 3 it says to dimple the bottom only. But I can not find when it says to dimple the tops, and I have fairly closely read the entire manual. It seems like it would be MUCH easier to dimple everything that needs dimpling all at once. Obviously you need to pay attention and NOT do the ribs for the wing walk, but can I dimple the others at the same time?
Do the plans call for you to use a squeezer and dimple in place later on?
I have a 24" deep "C" frame dimpler I was going to use and just do it all at once, very efficiently?
RV-? in planning stages.
RV-14 #140050 SOLD
Permanently willing to contribute fuel for RV rides
Helicopter ATP/CFI(I)
ASEL/AMEL Commercial/Inst/CFI(I)
Aerobatic Instruction available
Atlanta based.
Old 07-06-2013, 11:20 AM
KCBerner's Avatar
That's what I did. I even did the wing walk and had to undo them but sounds like you've got that part figured out. I don't know any reason you wouldn't dimple the top of the rest of them.
K.C.
RV-14A #140026
Old 07-09-2013, 09:07 PM
Scott Hersha Scott Hersha is offline
The upper flange on the wing walk ribs aren't dimpled, because the doubler skin laying on top of this area isn't dimpled. The top skin is dimpled and the underlying doubler skin in the wing walk are is machine countersunk to accept the dimples in the top skin - leaving the underlying surface of the doubler surface smooth. If you've machine countersunk the doubler, per plans, you'll have to 'undimple' the upper rib flange as suggested by Vans.
SH
RV6/2001 built/sold 2005
RV8 Fastback/2008 built/sold 2015
RV4/bought 2016/sold/2017
RV8/2018 built/Flying
Cincinnati, OH/KHAO
JAN2019
Old 07-09-2013, 10:59 PM
PRE911 PRE911 is offline
Unhappy Inboard Wing skin dimples vs countersinking
Hi Scott,
Respectfully, please reconsider your advice.
I think you are NOT to dimple the upper flanges of the number 1-2-3-and 4 ribs because the flanges are to stay flat as are the wing walk doublers, and the top skin. I think you are to countersink the top skin that overlies the wing walk doubler and the first four ribs.
Reference:
Page 14-02 step 4, second paragraph not to clearly states "machine countersink all the rivet holes that CORRESPOND to the doubler. The key word being CORRESPOND. That means the holes on the w- 00002 skin that are over the wing walk doubler holes and rib flange holes. It also directs to countersink shallow as prefered to too deep. I believe that is for strength (not to remove too much material during the countersinking for the rivets.
These directions are not very clear to me as we'll as some other sections. I was about to countersink the doublers as well until a friend stopped me.
Please correct me if I am wrong.
Full disclosure. As much as I try and ready everything several times before I drill or dimple anything, I dimpled about half of the outboard wing skin holes on that one row that it spicifically said DO NOT DIMPLE, and had to flatten them out. My Bad.
Rich
Building RV-14A. #140061
RV 14A N2261 flying as of 7/22/16
KDVO Novato, Ca.
Rich
Old 09-13-2013, 03:29 PM
propsync's Avatar
propsync propsync is offline
Originally Posted by PRE911 View Post
Hi Scott,
Reference:
Rich
Just completed this step yesterday. Rich, I believe your assessment is exactly correct.
Nick, I'm with you. I'm scratching my head on why vans didn't give the go ahead back in 12-02 to dimple the top of the ribs (except the 4 inboard ribs). Not to big of a deal though I suppose, the pneumatic squeezer just fits but holding it is a little awkward.
Tom B
Tampa, FL
EAA - Tampa Exec Airport
Old 09-13-2013, 04:34 PM
Stockmanreef Stockmanreef is offline
I guess i missed this on the plans like others. I dimpled the top and bottom of all the ribs when I was on 12-02.
So at this point, I guess I will undimple the 4 inboard ribs.
The main issue is that I also dimpled the top holes of the torque tube support bracket and then I riveted it in place. So now the two top holes in this area can't be undimpled. Correct? Or should take off the torque tube assembly and undimple?
Just undimple all the other holes.
I am just wondering how many other things I am going to miss in the plans.
Ken Stockman
Midland, MI
EAA Chapter 1093 member
RV-14a (serial number 140073)
N73XP (at least that # reserved now)
