Old 06-16-2013, 03:00 PM
LAMPSguy's Avatar
LAMPSguy LAMPSguy is offline
Default Wing rib holes off
Anyone else notice, or have any problems with the third hole back, on each of the top and bottom rib flanges? Basically, if you look at the rib flanges from front to aft, the third one back is NOT inline with the others, this occurs in every rib I have. Incidentally, none of my ribs were covered in blue plastic...the only part of my kit to arrive this way.
RV-? in planning stages.
RV-14 #140050 SOLD
Permanently willing to contribute fuel for RV rides
Helicopter ATP/CFI(I)
ASEL/AMEL Commercial/Inst/CFI(I)
Aerobatic Instruction available
Atlanta based.
Old 06-16-2013, 06:12 PM
flion's Avatar
flion flion is offline
I don't have a -14 but with experience on two kits, I'd advise you to send those back to Van's. They'll make it right; it just looks like a manufacturing error that didn't get caught before shipping. None of the holes shown in your picture are where they should be on the flange.
Patrick Kelley - Flagstaff, AZ
RV-6A N156PK - Flying too much to paint
RV-10 14MX(reserved) - Fuselage on gear
http://www.mykitlog.com/flion/
EAA Technical Counselor #5357
Old 06-16-2013, 06:52 PM
LAMPSguy's Avatar
Default Mispoke
Actually, they are the 3rd back from the spot where the J stiffener goes through. Anyone else think I should send them back, or at least call? I have already put a lot of work into them.
RV-14 #140050 SOLD
Atlanta based.
Old 06-16-2013, 08:16 PM
KCBerner's Avatar
KCBerner KCBerner is offline
Default None of mine looked that way
I'd send pics to vans. I bet they just send you new ones.
All of mine looked more like this:
K.C.
RV-14A #140026
Wings 70%. Started on the Emp.
www.KCandAshleyBerner.com
Happy to be a 2016 =VAF= contributor
Old 06-17-2013, 03:04 PM
LAMPSguy's Avatar
Default FYI
Vans said "by design", build on!
RV-14 #140050 SOLD
Atlanta based.
Old 06-17-2013, 03:17 PM
MarkW's Avatar
MarkW MarkW is offline
Somebody is misunderstanding something.
Can you give us a picture like the one K.C. is showing.
If I see corectly what you are showing us, that ain't right.
What about edge distance? Your rib will not be straight and therefore not as strong as designed.
RV9 - N14MW - Flying
G3X - ECI Titan I0-320
Catto three blade prop
http://www.mykitlog.com/MarkW
Old 06-18-2013, 09:36 AM
flion's Avatar
I think I get it. That original picture is with the flange behind a straight-edge to show that the holes are not lined up. It just looks like the holes are at the edge of the flange. I suspect that without the straight-edge, his flange looks like K.C.s and Vans is correct, there is no problem. Pictures may be worth a 1000 words, but they can also lie.
Old 06-18-2013, 04:03 PM
LAMPSguy's Avatar
Default Difficult
It is, of course, difficult to explain this online. I would say the way I noticed it as a visual representation of how you "feel" if a hole/edge is deburred enough...just feel it.
Well, the holes just "looked" crooked.
Here is a straight edge for reference
The third hole forward of the space is out a bit
Between these pics you can quantify it as being about 1/64 - 1/32 more outboard from the rest of the holes
RV-14 #140050 SOLD
Atlanta based.
Old 06-30-2013, 01:44 PM
OLDSAM OLDSAM is offline
I'm building a different model, 7A, but I would just make sure to leave that particular hole open on each rib when you cleco the skin on for drilling the first time. I expect that by the time you cleco the holes on either side, and match drill that one, everything will fit together just fine. As an exercise, you might cleco the matching skin onto a couple of the ribs before assembling the wing structure, and notice if there is any noticeable distortion of the rib web with that hole, and the next 2 or 3 on each side, clecoed together. I kinda doubt there will be anything significant, and not anything that match drilling won't take care of. My $.02.
OldSam
RV7A, Empennage, Wings & Tanks complete
Fuse under way
