LettersFromFlyoverCountry
A week ago I was installing the yoke-to-bellcrank pushrod for the right wing on my RV-7A when I thought, "I should check to be sure that half the threads in the rod end bearing are inserted into the pushrod.
I was surprised that they weren't and further surprised that it wasn't the proper rod end bearing on the pushrod I was looking at on the plans. "How did this happen?" I wondered. I just assumed that I must've put the longer rod end bearings in the HS or VS and at this point, I'd rather spend the money than take those apart.
So I ordered two new rod end bearings ($14.95 each) and installed them this weekend.
Today I took the left one off and, I'll be darned. Same problem.
I doublechecked the plans only to discover I was looking at the ELEVATOR pushrod callout, not the AILERON callout.
I also doublechecked that the pushrod was built to exact specifications lengthwise. It was. Even in the plans, it appears that half the threads aren't engaged.
So I'll order two more rod end bearings and construct it to the -- in my opinion -- safer elevator pushrod specifications.
My plans are pretty old, as I'm builder #240. Can anyone who's got newer plans check to see if Van's has changed their callouts here?
