Saville
Hi all,
I'm new to metalworking so today I'm practicing on scrap metal and running into a problem:
I'm trying to drill and countersink for an 8-32 flat head structural screw (1/2" long) in 0.063" thick material.
I'm using a nylon-faced micro-stop.
I start by drilling a clearance hole with a #19 drill. This makes a great hole - no slop.
Then I used a #20 Avery countersink in the micro stop and attempted to dial in the countersink depth.
I started shallow by (it turned out) about 5/1000's and so I increased the depth by 1000th increments to the point where I do not catch a thumbnail on the screw head BUT.....
....the clearance hole is now wider and there's a little slop in the hole.
Is this expected?
Or, should I start with a smaller drill and a smaller countersink cutter and then the increased hole diameter will work out to be perfect for the 8-32?
Please advise.
Is this expected?
Please advise.
