Old 08-08-2018, 08:56 PM
KC10FE's Avatar
KC10FE KC10FE is offline
Default Wanted RV7 wing jig in Colorado Springs
Does anyone have a steel floor mounted wing jig they want to get rid of? I am in Colorado Springs?
Erik Lanning
Colorado Springs, CO
USAF (Retired), KC-10 Flight Engineer
RV-7A (Empennage in progress)
Old 08-08-2018, 09:01 PM
johnbright's Avatar
johnbright johnbright is offline
Default Does one need a jig?
Curious, isn't the wing self-jigging; pre-punched skins and sub-structure.
John Bright, RV-6A 25088, at FWF
O-360, 8.5:1, vert sump, SDSEFI EM-5
Z-14 adapted for EFI, wiring and IP CAD files here
Newport News, Va
Old 08-08-2018, 10:27 PM
KC10FE's Avatar
Default Wing jig
If you follow the recommendations by Vans.......then yes! The jig insures that you donít build any twist in the wing. Even though the kit is pre-punched, there is plenty of room for error.
Erik Lanning
Old 08-09-2018, 12:20 AM
ksdflying ksdflying is offline
I second this. Absolutely build a wing jig. level it in, square it in, and plumb-bob it. No question about it.
Old 08-09-2018, 06:29 AM
herb.b herb.b is offline
Default wing jig
I have a set that I am done with. They are looking for a new home to be used again. I am in central Illinois.
Old 08-09-2018, 07:40 AM
jcarne's Avatar
jcarne jcarne is offline
I just ran posts from floor up to the trusses and clamped the spars. I'm guessing your in a finished garage and need the steel ones to the floor.
20180330_150211 by Jereme Carne, on Flickr
Jereme Carne
PPL
RV-7A Emp. done
Wings mostly done
Fuselage almost done
Finish kit arrived
Exempt but gladly paying!
Old 08-09-2018, 07:51 AM
wirejock's Avatar
wirejock wirejock is offline
Default Google group
Eric
Post to our group. Bob has the set I built. He may be finished with wings.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 12/27/2018. Plus a little extra.
Disclaimer
Old 08-09-2018, 08:59 PM
KC10FE's Avatar
Default Wing jig
Thanks gentlemen! Herb....how much do you want for them? Cost for shipping?
Larry....I will check with our group as well.....thanks again guys!
Erik Lanning
Old 08-10-2018, 07:04 AM
SeanB's Avatar
SeanB SeanB is offline
Default Rolling stand
Erik,
When you get the wings finished, I’ll have a rolling wing stand if you want it.
http://www.kitlog.com/photos/project...2015A0001H.jpg
SEAN BLAIR V7
http://www.mykitlog.com/sblair
2018 VAF SUPPORTER
Old 08-10-2018, 03:27 PM
I just want them to be in a new home. I can check on shipping but I expect it not to be cheap. They are heavy.
