N130WN
I just fit the exhaust to my TMX IO360 parallel valve engine, and I'm now looking where the heat muff might go. Off #1 is the easy answer, but would make for some crazy-long scat runs. It looks like it might work off the number #4 pipe, but it would barely clear the sump and the neighboring #2 pipe. If it works, the scat runs would be much nicer. Has anyone done it?
