Old 05-22-2018, 08:29 PM
Default intersection fairing rain and bird **** tape
the plane sat on the ramp in Wichita for 10 days while I painted my father's house. before I departed I placed tape on the intersection fairing thinking it would keep the rain out. it worked well and it also kept all of the bird **** out too. you would not believe all of the bird s h i t running down the vertical stab.
cleaned. picture of the tape.
even some rain would not remove the evidence. stuck like glue.
first time to use an airless sprayer. for what it's worth, a picture of the cart we fitted for the pump. I was pleased with the results. I transported the pump in the RV. No disassembly required. Behr paint. Did not thin the paint.
Old 05-23-2018, 07:28 AM
[/IMG]
I believe you Steve. Parked couple years under the elements the best season for me is winter. No toxic poop in February.
Ask Amanda to invent an attachment on top of the VS/rudder to keep flying cows off.
Old 05-23-2018, 11:57 PM
VA Maule VA Maule is offline
Default Bird poo
Probably would be easy enough to fabricate an anti bird rousting strip like that are installed on cell towers,building ,ect. There simply a bunch of wire quils a little bit longer than the legs of the target bird types. Just a bunch of safety wire "U's" stuck up through a pool noodle or pipe rap insulation on about 1" centers with a duct tape liner to hold the wires in and serve as scratch protection of the paint will deter birds from lighting.
Maule MXT-7(daily flyer)
Lancer 235(partner)
Raidial RV-8R Ephanage Done, Wings Done, Fuselage on it's tall Grove gear & engine hung
Old 05-24-2018, 01:10 AM
az_gila's Avatar
az_gila az_gila is offline
Smile
Just like the new rain gauge collector I had to buy for my weather station. The bird c**p used to clog the hole at the bottom with the original spikeless one.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 05-26-2018, 06:53 AM
Default powder coating
I talked my Father into power coating his iron work. I think he is happy with it.
