Old 10-01-2019, 10:58 AM
greghughespdx's Avatar
greghughespdx greghughespdx is offline
Default Updated version of RV-12iS Maintenance Manual has been published
Van's has published a new revision of the RV-12iS Maintenance Manual. The list of updated items is below, and the PDF document may be downloaded from the Service Information section of the Vans web site.
https://www.vansaircraft.com/service...ance-manual-2/
RV-12iS Maintenance Manual v3.1 – Change List
  • 1-21,22: INSTALLED EQUIPMENT LIST, updated the Skyview Weight and Arm values
  • 3-8: FIREWALL FORWARD, removed cotter pins as inspection item
  • 3-9: FWALL FWD, added “Check exhaust sys. ball joints for proper anti-seize lube”
  • 4-2: Moved “Cherry Max CR series rivet ...” note to Page 17-3
  • 14-2: “EX-00030” in the Components table was “Muffler Assembly”
  • 16-3: Added QR code link to how to video to access ROTAX 912iS fault info in EFIS
  • 17-3: Revised “rivets” section
  • 18-3: Added ELT Self-Test, Insp. bat. Life for RC Panel & Audio Alert Ind.
  • 18-15: In the INSPECTION CHECKLIST add the “Self-Test”
Greg Hughes - Van's Aircraft - Community, Media, Marketing
Van's web site | Instagram | Facebook
Opinions, information and comments are my own unless stated otherwise. They do not necessarily represent the direction/opinions of my employer.
Building RV-8A since Sept 2014 (N88VX reserved)
Dual AFS 5600, Avidyne IFD 440, Whirlwind 74RV, Superior XP IO-360
VAF build thread - Flickr photo album - Project Facebook page
Aurora, OR (EAA Chapter 105)
