Old 03-26-2013, 07:41 PM
Brantel's Avatar
Brantel Brantel is offline
Originally Posted by n38139 View Post
Maybe...but I know this one works:
Brantel (Brian Chesteen),
Check out my RV-10 builder's BLOG
RV-10, #41942, N?????, Working on Emp/Tail Cone
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 03-26-2013, 08:44 PM
SteinAir SteinAir is offline
It will work...and though it is low cost, realize the item is located and will be sent from china. Just an FYI, we do keep these in stock and usually provide them with the GDL's when we sell those....and yes....it's real gold!
Stein
Old 08-17-2014, 03:03 PM
RV-4 RV-4 is offline
Thumbs up SMA TO BNC CABLE
I just installed my GDL-39 3D in the tail of my RV-4 and hooked it up to ones of Don's UAT Antenna.
I used a SMA to SMA cable ( 6' long, so plenty long for an RV-4 installation) and used a BNC to SMA connector from the antenna to connect it to the cable.
It works great and cost a total of about $15.00 CDN.
YMMV
Bruno
rv4@videotron.ca
2019 Due paid gladly
Old 08-17-2014, 04:16 PM
First, another shameless plug for Don's antenna!
As for the cable, I measured the routing distance and then found a nice option for the exact cable with correct fitting from the "aviation department" at Amazon.com :-)
Old 08-18-2019, 05:45 PM
sglynn's Avatar
sglynn sglynn is offline
Default antenna for GDL 39 on dash
Is there an antenna I can plug into the GDL 39 thru a cable so that I can put the antenna on the glare shield and the GDL 39 body under the panel so it is ut of the sun and only the antenna is in the sun?
Would it work if I just used the existing GDL 39 antenna but connect it thru a RG400 cable to the body instead of directly to the body of the GDL 39?
Steve Lynn
RV-7A
Flying Phase I
Anacortes, WA
www.mykitlog.com/sglynn
Old 08-18-2019, 08:13 PM
blackbeard10's Avatar
blackbeard10 blackbeard10 is offline
Default deltapopa antenna
Ditto on the superior quality of the deltapopa uat ant.
Mark Wyss
Madison WI
RV4
0 360 A1A Ellison throttle body
PMags
Trutrak Efis
Catto 3 Blade
FLYING
Old 08-18-2019, 09:00 PM
RV8JD's Avatar
RV8JD RV8JD is offline
From the GDL 39 Accessories page on the Garmin website:
Here is an ADS-B Antenna Extension Cable from Garmin:
https://buy.garmin.com/en-US/US/p/pn/010-11825-10
And a GA 25MCX Remote GPS Antenna from Garmin:
https://buy.garmin.com/en-US/US/p/pn/010-10702-00
Carl N.
Arlington, WA (KAWO)
RV-8, 705 Tach Hours
(Pic 1),(Pic 2)
(Pic)
Glasflügel Standard Libelle 201B - Sold
Rolladen-Schneider LS1-f - No longer owned
Old 08-19-2019, 12:06 AM
sglynn's Avatar
Default Cable for GDL 39
Steve Lynn
RV-7A
Flying Phase I
Anacortes, WA
Old 08-19-2019, 07:22 AM
Thermos's Avatar
Thermos Thermos is offline
Add me to the list of satisfied DeltaPop customers, Don is a great guy and makes great antennas. If you need an external 978/1090 antenna, buy one of his.
Dave
Dave Setser
RV-7 airworthy!
Nashua, NH (KASH)
Putting the "slow" in slow-build since 2004!
