Old 09-25-2019, 01:14 PM
David-aviator David-aviator is offline
Default FLAP HANDLE RELEASE BUTTON....
....The spring seems too tense, it takes two hands to push the button to raise and lower the flaps. I've lubricated the mechanism, not much help.
This is an early kit, has the spring perhaps been replaced with something with less tension?
Airplane coming together, brakes serviced yesterday, no bubbles in any line and pedals are solid. Floor panel installed to facilitate setting elevator cable tension, a mechanic is doing that for me.
Closing in on first engine start.
dd
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
I'm in, dues paid 2019 This place is worth it!
Old 09-25-2019, 02:13 PM
Air-ic Air-ic is offline
Default N 15-10-01, Flap Handle Button Actuation Force
I believe this is what you are looking for.
https://www.vansaircraft.com/service.../n-2015-10-01/
Aric Krause
A few RV-12s
Old 09-25-2019, 03:21 PM
Mich48041 Mich48041 is offline
While you have the flap handle apart, modify the button or replace it with Van's new button if it has not already been done. Read this thread:
http://www.vansairforce.com/communit...d.php?t=126733
Instead of modifying the original spring, I replaced it with a weaker one.
https://www.centuryspring.com/catalo...cdskeys=72144S
Joe Gores
RV-12 Flying
Old 09-25-2019, 08:37 PM
Thanks for the quick response guys, I will get the thing fixed one way or another. I was thinking no-flap operation with it as is.
I believe the latest RV-12 kits have electric flaps...that would be nice.
dd
RV-12 Build Helper
RV-7A...Sold #70374
