Old 03-11-2016, 09:50 PM
When the airplane was originally advertised for sale I looked at the photos and posted video and considered buying it. The photos showed that the airframe was very much repairable. In fact less damage than my RV-6A and that I had flying again in about 7 months
Kent has posted photos of skins being carefully removed as if planning to replace them, and even mentioned pulling out dents, so it sounds to me like repair vs replace is being done wherever possible.
I have not met Kent (though I would be happy too... it sounds like he is located near me and we have something in common.... extensive rebuild of a wrecked RV) and have nothing against him. My comment was only in response to Bills suggestion that it could be certified as a new airplane.
Now if the airplane had been purchased just for the major components like the control system, landing gear weldments / legs, etc., and an entirely new airframe was built using those parts; then I agree it might be doable depending on what was used.
That is my opinion, with my level of understanding of the rules.
Anything beyond that I defer to Mel or Gary. As active DAR's, they likely have an opinion of what level of reuse for a new build they would allow, and what process would be used to determine eligibility.
Scott McDaniels
Hubbard, Oregon
Old 03-13-2016, 03:43 PM
bret's Avatar
bret bret is offline
Did you take all critical measurements before disassembly? wing sweep, tail to wingtips ect, might give an incite to what is bent, stretched longeron, twisted center section....post pics, very interested in your project!
2019 gladly supported
Old 06-04-2016, 03:19 PM
kentlik's Avatar
kentlik kentlik is offline
Upon much investigation, I will be building the entire center section new. One entire wing. Finish up emp. Re skin 2nd wing and check dent in tank, possible new tank.
All the electrical, panel, and FWF.
Plus of course the sliding canopy and firewall and the balance of the reinforcement pieces. All in all, I am building a new aircraft, but why not!
Kentlik
RV-7A in progress
http://www.imdb.com/name/nm0527486/?
Private pilot, ASEL!
EAA 105 Chapter 7S3
Bi-annual financial contributor
"The credit belongs to the man who is actually in the arena..." Teddy Roosevelt
Old 06-28-2016, 02:25 PM
kentlik's Avatar
Default bucking rivets
Moving forward...thanks for the help Darrell of Aurora/Hubbard, OR.
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
Old 07-18-2016, 10:15 AM
kentlik's Avatar
Default Bulkheads
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
Old 07-22-2016, 08:30 PM
Blain's Avatar
Blain Blain is offline
Default Drill bits
How many number 40 bits have you gone through?
Blain
R-22 sold.
RV-8 AW Cert 02-09-17
N82 Sierra Tango
Avatar courtesy of AircraftStickers.com!
Dues gladly paid thru Nov. 2019(my reminder)
Old 07-28-2016, 09:38 PM
kentlik's Avatar
About four. I am using cobalt, much longer lasting...lol
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
Old 08-10-2016, 09:34 AM
kentlik's Avatar
Default Drilling rivets to remove center section
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
Old 08-10-2016, 04:38 PM
Snowflake's Avatar
Originally Posted by jbDC9 View Post
This thread from 2 months ago should explain the background on this project...
http://www.vansairforce.com/communit...d.php?t=133682
Unfortunately that link no longer goes to a valid thread...
Rob Prior
Old 08-15-2016, 05:31 PM
kentlik's Avatar
Default Some bent stuff being repaired and some straight stuff
Made some good headway last couple days. Slow but this is going to be rewarding as it is difficult.
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
