looking for a new instrument Panel face
rrjohns
Member
I'm looking for some info on where I might find metal, fiberglass or carbon fiber
blank instrument panel for a RV9A with a tip up canopy.
I have an Affordable panel XL model for a RV9 Tip Up. It is a tall panel with more area than stock. I planned a complex panel, but later went to a minimum panel and used the Vans stock panel.
It is in storage, but I will get it out if you have interest.
Thanks for the info very helpful
Thanks for all the info it is very helpful I will look up the part # and order from and order from Vans
Just download the pdf file from Vans, print it out, pick up a piece of aluminum and cut it. I went to a scrap dealer and got a piece for about $15 and it took about 15 minutes to cut it out, use my belt sander and then the scotch brite wheel to finish it off perfect. I did have a HVAC friend put the 90 degree bend on it for me since I don't have a brake. I wanted my panel a little taller than the stock part and to incorporate the vents a little different.
