Old 03-19-2017, 09:25 AM
skidookid skidookid is offline
Default need apple I pad to run garmin piolt
Tried galaxie android to run garmin pilot but missing info and slow. What I pad should I by to use in my rv 8 with limited space. thanks rt
Old 03-19-2017, 09:49 AM
pyolet's Avatar
pyolet pyolet is offline
Any iPad Mini with cellular data will work, but can also go with a cheaper no-data model, and wifi tether to any hot spot enabled cell phone. The more memory the better...I have 16 gig memory in my iPad mini, and had to delete all unnecessary apps. Wish I'd gone with 64 gig.
RV-7, IO-540 , Hartzell 80" blended CS. Flying since 2011. Classic Aero 3 tone leather int. Dynon Skyview, 261, 429, 470, dual ADHRS, Garmin GNS480W, SL40, GMA240, Anti-Splat-Aero air/oil sep, EZ-cowl flaps, Koger wide sunshade.
=VAF= donor 2017
Old 03-19-2017, 10:26 AM
agirard7a's Avatar
agirard7a agirard7a is offline
Default Garmin pilot
I run Garmin pilot on an IPAD mini with cell service for the gps function.
Also have an IPhone 7 running as a backup. Both blue tooth to a gdl39 for weather and traffic. Love it! Agree, get the higher storage models of both.
Al Girard, Newport, RI
N79LG
RV 9a
on the fuse.
Old 03-19-2017, 11:38 AM
Question i pad question
Does I pad have built in gps or do need to buy a separate device to for gps feed?. Do I need phone part of I pad to work? .I only use I pad in plane. rt
Old 03-19-2017, 01:25 PM
RV6_flyer's Avatar
ONLY iPad that has Cellular chip has a built in GPS. You do NOT need to have cell service activated for the GPS to work. List price is an extra $130 for the Cellular + WiFi iPad. There are very few GPS devices available that are less than $130 plus then you have an extra device to break, need charging, or to forget.
IMHO, you will want the latest iPad as I find my older units too slow for me. I expect that a new iPad mini Pro may be announced at the next Apple Event sometime in the next several weeks. A new or update will lower the price of existing iPads.
Gary A. Sobek
KVVS RV-6
Flying
3,200+ hours
Building RV-8 S/N: 80012
Old 03-19-2017, 02:01 PM
moll780 moll780 is offline
I have this exact setup. iPad3 64gb 4g not activated.
Also use Samsung Galaxy s7 edge. both work fine and are fast. No problems with SG7.
--2008 RV-9A
Austin TX
Old 03-22-2017, 07:02 AM
mikeos98 mikeos98 is offline
Default garmin pilot on adroid.
I am running the asus zenpad 10.1 with verizon card. I love it. runs garmin pilot just fine while streaming music. no speed issues at all.
Old 03-22-2017, 12:13 PM
mark960 mark960 is offline
[quote=RV6_flyer;1159167]ONLY iPad that has Cellular chip has a built in GPS. You do NOT need to have cell service activated for the GPS to work. List price is an extra $130 for the Cellular + WiFi iPad. There are very few GPS devices available that are less than $130 plus then you have an extra device to break, need charging, or to forget.
IF, you are using it to view ADS-B traffic and weather, many of the ADS-B receivers have GPS built in. I use a Garmin GDL-39 and it has the GPS built in.
So, if you plan on using only this app in your aircraft, you CAN get away with a iPad with only 16G and NO GPS (so long as you ADS-B in has it) That being said, you will probably find that you want to use the iPad for a number of other apps and will be happier with 32G of memory.
Old 03-23-2017, 11:04 AM
Pool Shark Pool Shark is offline
First, I Am a confirmed Android guy, but after extensive research, I discovered that the only viable option for Garmin Pilot is the iPad.
I got the iPad Air 2 (64 GB) with cell cabability (the only way to also get GPS), but I have NO PHONE/DATA PLAN. WiFi works great while on the ground (flight planning) and I use Flightstream from the Console Garmin while in flight (so I get AHRS and ADS-b)
Been using it for just over 6 months, and LOVE IT!
Right after I went to all the trouble to create a customized Excel spreadsheet for weight & balance, Garmin added that function to Pilot; really comes in handy.
Anyway, I find the Air 2 is the perfect size and works really well.
The only other advice I can give is spring for the extra memory: definitely get the 64 GB version of whatever iPad model you get.
Chris Staiger
Baker's Acres, CA
RV-10 #1711
VS, Rudder & HS Complete 1/29/17; Now, bring on those Elevators...
(VAF Dues Paid thru June, 2020)
Old 03-23-2017, 11:19 AM
sirlegin's Avatar
sirlegin sirlegin is offline
I use Garmin Pilot on a Galaxy note 10.1 2014 edition and it works perfectly and it sync's with the GDL to get traffic, weather and terrain at a high speed. No problems thus far.
Nigel
RV9A-N113SQ
52F
