Old 03-04-2017, 05:46 PM
blaplante blaplante is offline
Default For Rent: Garmin 400W/500W Main Software update (ADS-B)
As we all start to look at ADS-B output requirements you may think your Garmin 400W series (430W) or 500W series GPS can provide GPS position data to your new ADS-B out transponder (Garmin or Trig TT31 for example). I discovered, yes it can, but only if you have the newer software installed in your GPS that will provide the expected data feed. Mine was too many versions back.
The procedure to update is pretty simple, I'll include the Garmin instructions, but to get an idea of the procedure see https://www.bellcustomer.com/files/S...9-15-41-RA.pdf
The only real catch I can see is be SURE not to lose power mid-update, as that can leave you with a corrupted system that only Garmin can fix. I've run this on my GPS and it was pretty easy.
I have the two software cards that bring your main software to version 5.30, and the GPS to 5.0
You can see your current version by powering up your 400W/500W series GPS and look for the first text message.
Your current Main SW version must be 3.30 or newer to be compatible for this update.
Rent them from me for $50. If you are in So. Calif., you could come to KOKB and I can help you.
Just to be 100% clear this is not the NAV or obstacle data.
Send me a PM if interested.
-Bryan
RV6A in phase 2 as of April 2016
Donation made May 2016
Last edited by blaplante : 03-05-2017 at 09:49 AM. Reason: Clarify minimum version
Old 03-04-2017, 06:15 PM
Where were you 6 months ago? I had to pay a dealer $100 for the < 15 minute upgrade. So half price is a good deal.
(Just to add to your comment: If people look at their 4xxW/5xxW setup pages, and look at what formats are available for RS232 outputs, they should be looking for "ADSB+". That's what you need. If you only have "ADSB" that's not good enough, you need to upgrade the software.)
Old 03-04-2017, 06:46 PM
Isaac's Avatar
Isaac Isaac is offline
Default GPS Update
Sent you a PM
James
___________
James
RV6 N947J
Old 03-05-2017, 10:44 AM
airguy's Avatar
airguy airguy is offline
Put me in line, I need this!
PM on the way...
Greg Niehues - VAF 2017 dues paid
Garden City, TX
N16GN flying! http://websites.expercraft.com/airguy/
Built an off-plan 9A with too much fuel and too much HP. Should drop dead any minute now.
Old 03-05-2017, 03:49 PM
Gash's Avatar
Gash Gash is offline
I'm next after airguy! I need this too! I'll send you a PM. Thanks very much.
Karl, Goodyear, AZ (KGYR)
RV-8, Bearhawk
I donated to =VAF= for 2017
Old 03-06-2017, 06:38 AM
ecurington ecurington is online now
Default Put Me In Line
Sending PM.
Eulice Curington
RV-10, N104EW
Painting
Old 03-18-2017, 07:12 PM
Default Bump
bumping this, anyone else?
Old 03-19-2017, 05:46 AM
FORANE's Avatar
FORANE FORANE is offline
I would like to do it but my plane is at the paint shop currently so I don't have access. Might be a week or 2 before I can use it. Put me in line?? Give me a week or so and I will check back; don't want to delay return of the card...
Lancair 235/320
RV-9A (2013 - 2016)
Old 03-21-2017, 02:18 PM
CRW CRW is offline
Default Software Update
Sent you a P.M.
Best regards,
Chuck
