Old 10-31-2009, 03:35 PM
RVnoob RVnoob is offline
I am speechless...
I can't believe you would go through ALL that trouble to
make something so beautiful... that nobody would see.
It is genuinely a master piece.
Thanks for sharing... I have learned more than fiberglass techniques.
I have learned that the product is really a reflection of its maker.
Old 10-31-2009, 04:43 PM
David-aviator David-aviator is offline
Darn it, Dan, you're good at what you do.
I need to build a filter box for a K&N cone filter and have down loaded the entire thread to a pdf file for reference on how to do it. I've had lots of trouble getting a lay up to release from a foam mold and you've come up with an excellent, excellent method.
Mocha gratis!
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
I'm in, dues paid 2019 This place is worth it!
Old 10-07-2011, 10:54 AM
DanH's Avatar
DanH DanH is offline
Another illustration...a duct on the underside of a plenum lid. Carved/sanded foam, micro to fill the dents and divots, epoxy skin, light sanding, wax, PVA, and do the layup.
So simple a caveman.....oh, never mind
Dan Horton
RV-8 SS
Barrett IO-390
Old 10-07-2011, 12:03 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Here's a silly question Dan - where do you get the pink foam in blocks? ACS? Or local sources? (I hate the idea of paying shipping for a bulky block of mostly air!) When we made our cheek cowl extensions, we laminated up a block from a sheet of Home Depot insulation - gotta be a better way!
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 10-07-2011, 12:50 PM
DanH's Avatar
Originally Posted by Ironflight View Post
Here's a silly question Dan - where do you get the pink foam in blocks? ACS? Or local sources? (I hate the idea of paying shipping for a bulky block of mostly air!) When we made our cheek cowl extensions, we laminated up a block from a sheet of Home Depot insulation - gotta be a better way! Paul
That's it....pink 4' x 8' x 2" thick sheets from Home Depot. I like the stuff because it is very small cell.
Did you have some difficulty with laminating the block size you needed?
If you really want a giant one-piece foam block, find floatation billets intended for dock construction on your local lakes.
Dan Horton
RV-8 SS
Barrett IO-390
Old 10-07-2011, 01:06 PM
Ironflight's Avatar
Well, they only had the 3/4" when I went shopping, so it took a bunch of layers! We used spray adhesive, and it worked "ok", but it left some voids in places that took a little extra work. 2" would be a lot better!
Great tips - as usual! We still have intersection fairings to make....
Paul F. Dye
Old 10-07-2011, 02:52 PM
DanH's Avatar
Ahh, spray adhesive isn't so good...solvents melt the foam. Use a very thin layer of dry micro* instead.
Look close and you can see two laminations (three blocks) in the above form.
(*microbubbles and epoxy mixed to the consistency of firm peanut butter. It sands better if mixed more "dry".)
Dan Horton
RV-8 SS
Barrett IO-390
Old 10-07-2011, 03:00 PM
Ironflight's Avatar
Do you peel the "skin" off before joining layers Dan?
Paul F. Dye
Old 10-07-2011, 03:05 PM
DanH's Avatar
I have used some thin (<1") small-cell blue foam sheet with a plastic film on it, and yes, you need to peel the plastic. The 2" pink foam sheets don't have a plastic film.
Dan Horton
RV-8 SS
Barrett IO-390
Old 10-07-2011, 05:29 PM
Bill Wightman's Avatar
Bill Wightman Bill Wightman is offline
Default Foam Block surfacing
Dan, looks like we use nearly identical technique. I have an alternate way to produce the desired release surface on the foam tool: Mix up some plaster of paris (gypsum plaster) and squeegee it on.
Using a squeegee, it will penetrate the foam enough for good adhesion and then sands quickly to a nice finish. The plaster also fills voids with ease. If you sand too deeply into the plaster, the area will require a re-coat to get the surface back.
Finish with paste wax, and if needed some PVA before glassing the part up.
Really cheap, fast, easy and produces great results.
“The important thing in aeroplanes is that they shall be speedy.”
- Baron Manfred von Richthofen
RV8 under construction
RV4 - Sold
United B777 FO, Chicago
Aero Engineer
RV8
