Go Back   VAF Forums > Avionics / Interiors / Fiberglass > Glass Cockpit
  #31
Old 06-21-2017, 01:30 PM
Jasonm Jasonm is offline
Default G5 Version
I see in the G3X Touch software version 5.30 released in April of 2017 that the software for the G5 is version 3.10 but 3.20 is out as a standalone version. Can I update my G5, currently running 3.10 to 3.20 without causing problems with my G3X Touch panels?
Jason McKay
Old 06-21-2017, 06:41 PM
Pat Hatch's Avatar
Pat Hatch Pat Hatch is offline
Yes. Just did it myself a few weeks ago.
Pat Hatch
RV-4 (Gone to RV heaven)
RV-6 (N44PH - Flying)
RV-7 (Sold)
RV-8 (Builder & Avionics Installer)
www.phaviation.com Trim Relay Boards/Flap Actuators
www.pathatch.com/blog (Photography)
Track Me
Old 06-22-2017, 06:09 AM
swordtail swordtail is offline
I have NOT had a single problem with my G5 in 45 hours of flying in 6A.
Rock solid
Old 06-22-2017, 06:20 AM
Brantel's Avatar
Brantel Brantel is online now
Right or wrong I have updated my G5 to newer versions than what have been embedded in the G3X Touch updates and have never noticed any issue with doing so. For a much longer time frame, the same for the GDL39.
Brantel (Brian Chesteen),
Check out my RV-10 builder's BLOG
RV-10, #41942, N?????, Working on Emp/Tail Cone
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 07-10-2019, 02:54 AM
DeeCee 57's Avatar
DeeCee 57 DeeCee 57 is offline
Location: Zürich W, Switzerland, Europe, Earth, Milky Way, known Universe...
Granted the air was not smooth but I did not expect the constant "alignment"
Well, running software 6.0, my faith in the G5 got a severe dent a couple of weeks ago... flying between Denmark and northern Germany between huge cells, I got moderate then severe turbulence lasting more than 25 minutes. After about 5 minutes beating the G5 went into "ALIGNING" mode and persisted for about 15 to 20 minutes before it recovered...
Good thing VMC conditions prevailed
So, no IMC flying on the G5 standalone?
PS
Updated device yesterday to v.6.2, would be surprised if any was done about this difficult to replicate conditions problem.
Life's short... Enjoy!
DC
http://www.aerofun.ch
RV-4 #2062 HB-YVZ airframe builder
RV-6 #25685, slider, O-360-A3A (carb/dual Lightspeed II), MTV-12-B, HB-YLL owner
Old 07-10-2019, 06:22 AM
g3xpert's Avatar
g3xpert g3xpert is offline
Post
PS
Hello DC,
If you collected a flight data log to the G5 SD card during that flight, you can email it to us and we would be happy to review.
Steve
Garmin G3X Support
g3xpert@garmin.com
1-866-854-8433 - 7 to 7 Central Time M to F
Please email us for support instead of using Private Messaging due to the limitations of the latter.
Old 07-10-2019, 06:31 AM
Walt's Avatar
Walt Walt is offline
Originally Posted by g3xpert View Post
Hello DC,
Steve
Steve, never even thought about this or realized the G5 does it's own data logging. So it sounds like keeping a blank SD card in the G5 would be a good idea? Is this same data logged on the data card in the G3X?
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 07-10-2019, 06:57 AM
BCP Boys's Avatar
BCP Boys BCP Boys is offline
Default What Walt Asked
Thanks for asking this Walt. Curious myself.
Amir
RV-7 - My Ferrari in the sky
RV-10 - Partnered with a good friend
Supporting VAF since the first visit
Old 07-10-2019, 07:45 AM
DeeCee 57's Avatar
Thanks for the prompt response and as ever excellent Garmin service Steve
Unfortunately I hadn’t activated the logging function, but sure is now.
DC
Old 07-10-2019, 09:37 AM
g3xpert's Avatar
Post
Hello Walt,
Yes, if you put the G5 in configuration mode, and go to the Device Information, Diagnostics, Data Log page and enable data logging, you can log flight data to a 32 Gbyte or smaller SD card formatted for FAT32.
Like the G3X Touch data, this data is in .csv (comma separated value) format, but as you can imagine, the data is much simpler than your G3X Touch system logs, but has good information for diagnostic purposes.
I don't fly with an SD card in my G5 unless there is some data I want to capture.
Steve
Garmin G3X Support
g3xpert@garmin.com
