Old 06-23-2019, 08:54 PM
thompsonbr87's Avatar
thompsonbr87 thompsonbr87 is offline
Default Connector backshell/strain relief
Wiring a 430W, and the back shell with the connector kit doesn't have any strain relief. Or maybe it does, but 3 wires in a back shell sized for a 44 pin connector doesn't quite fill it. Am I missing something here? Looks like I could just fill the little cylinder on the rear of the back shell with to better immobilize the wires. Am I on the right track?
Barrett
Smyrna, TN - KMQY
RV-6A
Learning something knew everyday.
Old 06-23-2019, 09:41 PM
RV10Pilot RV10Pilot is offline
There is usually a bushing that goes around the wires to provide the strain relief on that type of back shell,
similar to this one
You could also use silicone rubber tape to fill the void.
Old 06-23-2019, 10:00 PM
Ok, so kinda what I figured. Connector kit didn't have any bushings or anything, so I'll find something to fill the extra space before tightening the ring down. Thanks!
Barrett
Smyrna, TN - KMQY
RV-6A
Old 06-24-2019, 07:31 AM
airguy's Avatar
airguy airguy is offline
I ran into the same problem, doubled-up with a couple layers of heat shrink in that part and it worked fine. Anything that will immobilize the wires with respect to the backshell (and not fall off later) will work.
Greg Niehues - PPSEL, IFR, Repairman Cert.
Garden City, TX VAF 2019 dues paid
N16GN flying 450 hrs and counting! Built an off-plan 9A with too much fuel and too much HP. Should drop dead any minute now.
Old 06-24-2019, 08:53 AM
Raymo's Avatar
Raymo Raymo is offline
Pick up a roll of F4 tape on Amazon = problem solved.
Ray
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
All lines by TSFlightLines
Old 06-24-2019, 11:43 AM
RV6_flyer's Avatar
Do not let the packaging fool you, this is the same stuff the Aerospace Industry uses only the packaging is different and at a lower price.
I worked 30+ years in the aerospace industry before I retired and this is the package I buy for my own use because it is the same stuff at a lower price with different packaging.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 06-24-2019, 11:54 AM
Looks like the same stuff I've been using from SteinAir. Slightly cheaper on Amazon per foot, but I've gotten much better customer service from Stein than Bezos.
Barrett
Smyrna, TN - KMQY
RV-6A
Old 06-24-2019, 08:10 PM
rapid_ascent rapid_ascent is offline
Hey Barrett,
I may have some of those bushings if you are willing to wait while I take a look in my hangar. I have a lot of leftover parts from my previous life.
Ray Tonks
2018 Donation Paid
RV-7 Fuselage in progress
* Rolled the Fuselage
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
Shop Setup - In Progress (Gathering Tools, Never Complete)
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
Old 06-24-2019, 09:45 PM
RV6_flyer's Avatar
Same here. If I have an order coming from Stein, I get it there. When I run out and only need one, Amazon Prime is easy plus fast.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Old 06-26-2019, 01:50 PM
vfrazier's Avatar
vfrazier vfrazier is offline
Or just squirt a small dab of RTV in there.
A small dab.... don't fill the danged thing.
Vince Frazier
www.f1aircraft.com
F1 Rocket and F4 Raider components
www.flyboyaccessories.com
RV and Rocket Accessories, Tailwheels, Tools, & More
1-888-8FLYBOY (1-888-835-9269)
F4 Raider - under construction
F1-H Rocket "Crazy Horse" - sold
RV-4 "Chief Pontiac" - sold
