Looking for blue aluminum pitot mast install pics
dsmithlib
I am planning to install Garmin GAP26 heated pitot.
Then I saw the blue aluminum mast with spar offset.
I would appreciate any pics of this mast properly installed.
Not much to it. Cut a hole in the skin with template. The forward flange of mast overlaps the spar flange - it ties in to three rivets that are common to the spar and wing skin. The rear part of mast is riveted directly to wing skin.
This is on RV-10.
eiX01hlzmuoRFyJ6KymWoxrrXrUYHJDy4dH-u5uSlP8VAU_cXrEjWe-hFQ415KaNYANPCCqaJ0sn596Ehz-c4JLj-9-54DVN0KXQg-FmP_zP0Mv7fb7n0xv092jfplGJuMeqgWuq1OFIIcile4kPXrKZjg8H0gPvJYC_l6-AWEOaahFr7XRTfM6K5iHIBqTQSkya8sorMmg_EbjpIQ9xY2HEmOMJHmmEmCVlzl0lf-UTD-LfetQ7ewlpnpa2ow_22Sz7tZlsLKiRSypCLs7I5_cID1XR6Xpp-LU9ywIPHBXbBNPKqJKLLkZKVwmUYkKljTiVoRW3OWWTSFpbCzTm_FEk92KHdD2ZSynwG5OeAvfDAEcTXGe6IU79ObRJR0gTk8D2ErG4cbyQOcBu4Bgd3dvkplsGPDD8ZCeyFxbSS14rCBLSf2iVmpvteCqau-z4yBvwwBjCEv_aMeQjazKNRFew2oavshW_HhPTjmCOd570_2SpafnOEH545UFuFPpn57ixLzt5EiDg74BBCkp3SlQwtvp6YyGswxc8ZSJ7kRWtfXvkqGw1c_-RwoLFh4ngk87kt7zxK47jwoiSk6IDeF2MQhdVTQIOwfZrt6QEnwkur0ENyP5iyvTAOmRP5EksdHCLF9pxwYNXdo_we93_scAwo4oLu2brmo3UK2SAt9MrSFdkVSZacGU=w600-h880-no
dMvYhrtPTp8MplUSySVimIXwQynIGUpXWZ5TaUQg5a6LZrUlj4w8sJVh2-ahhkY485Mqn7NpoVsciOkLB6TPGe3EW7SDyWCd0qKaWY2_Z_MyW1CdIdCG5Cs9nlLsRFfj6qDxKdVvlySe4TmLtSdjZhbK_tp8amP0RBPROlc5JvIR9rQndQHJfsH1gaXEN6yllbnp9fsBMKzU2TM34bYjXoFRLyF2BwTYVct5d1fqKUU0qCziiWjDbh7hsy2l1lYCtfG6rnrb0OOmbYR3ibH3vR42cLQo9iZQ549XM4ltSWoEyYF8ycbx48UnAm8De9924AciEG1USh-TJ1Hfb3dXZAscXcpi2ZFBST4c8gAtDuoKdtEMdGkUcowsI3eryeiYc2OOSi4m6fvuqqr3TRTRHmSsgNVhd0GpKbKYhrsSk3lhZhO2MuqX9STmXhAPA_ast6EZY7v9uiDMSa5qAw3K9I3TvfyyCedQ5gr_9W5ucvhrUtCLTrMUP6GJySlAgIAIPBMV70vHmfZaQYNr_5gkLkeVPGKleyLCuKlz0bLHfCiY5zxhYHnNjnJ6qDgGeg94uZk95CpO7hrOVyuqC9GOvC1eUu8XXwCL7wIO65qFlNyu4i6KW5Sy9nws7ceG5_HLChM1rB0jvMp8C69CBUAcJxRmHiZ4_MZaByEJ249MXxOE9-6XqwXm5eo=w600-h880-no
A_BklXLA-m9FAzLPf5GQABmtU_hPx3BFsnFMRybjMUs_1JfWGc49rKO4OcQnbPWNqrKDtuwpxD1faH7pdKrsgBFZkqJ77xSgiTEihPR8XNCq2q_YQrb04JI88jfmvmbbrNmT8lV8UZ5O1fWvzwV6tLF4oDrPq2qPeAvCSs4KMxgRNWRgy73xSfUTahnWpyqAwi7FdfgmpMo3JOFHS-ODo9aSD0XZd81plTDWvbFUmmaHuWHRF_kjHIkWFUP6vr-st1eCVKIvop4PHvdoARsvXbH-gJVA9Jiwfu16DPyVnm8wNum47UcJ0yqrad4vK9htayVOeHMrBC1jM8kod6rtsHdysVgk8T6z3vyHrQkO3curhk7NovT7Hvytw2Z2M6y0Cqw4XKBcx1b18LMXzzLIQqyQBONlYUbEt3ITX_4AARX08MnYN7D3B6v5S26cTid8_woJkqU8YGP87bBtZ9zT65VX0CGUT07NUpL6mVteAVNL868Llq1OlfEF-Eg2iJrrCJQ8RkzAuu1hmqN8kENOSH0i1qiVhM8tPB4LftmbUT0iYR2_JpyIEriWwuJq0EUGpJC1JltTPWwSGAgtpyDshRqh6jZqCQa4-y4hO3q3zlQ4YxlZ1z9rsKrqyq8EuBinG4Rwo_mWb24_EEM8hEmTDgXaKsKM6yynRYQWtWfW-6anks4KGIAKzo8=w600-h880-no
Not sure if this is the mast you're talking about but here's how I installed it onto my (not yet flying) 7A. I think no particular location is particularly correct, this is just what I chose. Choose what you think is most appropriate for your airplane. I decided on the wing bay immediately outboard of the outboard-most access hole:
I attached it to the spar and reinforced it with a small angle piece against the adjacent rib, and obviously re-did the unsatisfactory middle rivet:
For the pitot and AOA lines, I did what a lot of other builders did: built small brackets to route the lines safely under the bell crank:
Ryan,
Thanks for taking the time for those pics. My airplane is finished so I may choose the Gretz to avoid getting my bucking bars out !!
I have a finished RV-7. As suggested by one builder that installed the AOA/Pitot Probe on the outboard wing inspection plate. He mentioned a Gretz and using a doubler to strengthen the plate. Anyone have any pics on this install.
