scsmith
After reading some old threads on the subject, I am going to switch over to the higher-temperature hydraulic fluid, Mil-H-83232 (Royco 782).
I am replacing the O-rings in the brake calipers with Viton O-rings, Mil-R-83248-218.
Is there any reason to be concerned that the new hydraulic fluid might not be compatible with the rubber parts in my master cylinders? It is supposedly compatible with Mil-H-5606, even mixable. So I'm not planning to do anything other than drain the system and re-fill.
