I plan to have all my antennas externally mounted, no Archer antennas in the wing tips. The plan is for two comms, one loc/gs, two gps antennas, one marker, and one transponder. Just configuring the location for each.
The VOR/GS will be a Comant CI 157P antenna. I have seen some installed under the tail below the horizontal stabilizer. Question, can you access the inside of the tail in that location for install and removal or would it require my two year old grandson to be required to crawl all the way back in the tail to access the nuts once the tail is completed.
Second
Has anyone mounted an antenna under the tail, aft of the bulkhead. I have seen some mounted under the cabin.
Third
GPS antenna. Is it ok to mount one on the top of the cockpit between the doors. Any issues with it.
Thanks, Rich
Second
Third
Thanks, Rich
