Go Back   VAF Forums > Main > Reviews
Old 01-14-2019, 05:33 PM
DougJ's Avatar
DougJ DougJ is offline
This sound great! I havenít used this type of headset, but I have used the Communication Ear Plugs in my Army helmet. This looks like a great solution for the RV and you gotta love that comes from someone in our community!
Old 01-14-2019, 05:41 PM
BillL BillL is online now
Originally Posted by DGlaeser View Post
I
I literally make my own earplugs from these. I heat up a small wire (cheap hangers from the cleaners work great), poke a hole, and insert the tubes I pull out of the Halo headsets.
Hmmm, I make my own too. I have to try the hot wire method. I compress the plug axially to a small disc then use a leather punch to make the hole. Remove the plug and after they are expanded insert an awl and roll until it expands the hole and insert a recovered Halo tube with some super glue. My challenge is to keep the hard tube recessed a 16th of so to keep it from painful contact in my ear during insertion. I am only on my second set so, the process is far from refined.
It sure would be nice to eliminate this process, but have no guidance for the perfect product.
Bill
1st Flight 1-27-18
Phase II 8-3-18
Repairman 11-15-18
Instrument Currency 12-17-18
Old 01-14-2019, 06:56 PM
Sam Buchanan's Avatar
been here awhile
I found these: http://www.howardleight.com/earplugs/max.
I find them much softer and far (noticeably so) quieter than anything the current manufacturers provide.
For the short CA screw-in plugs, I literally insert a Halo tube into the CA plug, and cut it to the correct length for the earplugs.
Originally Posted by DougJ View Post
This sound great! I haven’t used this type of headset, but I have used the Communication Ear Plugs in my Army helmet. This looks like a great solution for the RV and you gotta love that comes from someone in our community!
Ah....another winter project.
I use the Communication ear plugs the Army helo drivers use when I fly the biplane. I ordered a bag of the Howard Leight Max foam earplugs and will attempt modifying them to work with the Army system.
Sam Buchanan
1999 RV-6
1918 Fokker D.VII replica
Old 01-14-2019, 07:11 PM
DaveWelch DaveWelch is offline
Default Waiting on the ad...
Originally Posted by DeltaRomeo View Post
....I'm waiting on the ad <g>.
v/r,dr
Awesome discussion. We've been looking at alternatives for our second ANR headset. We'll check out the CQ1 when we see the Ad!
Dave
RV12 N951DZ
First Flight 9/23/16!
No paint yet. Working on a scheme with John Deere colors or accents.
Old 01-14-2019, 09:20 PM
sahrens's Avatar
sahrens sahrens is offline
I just received my set today. I will give it a try in a few days when the weather clears up a bit. The headset does not use the same speaker system (CEP) I used under my Army helmet. The CEP system is a small speaker with a soft Comply ear tip that was connected to the helmet.
I will say the CQ1 headset is very lightweight and comfortable sitting in my house.
Scott
RV-7 N818BG (flying)
Bearhawk Patrol (building)
Old 01-15-2019, 12:17 PM
tomkk's Avatar
tomkk tomkk is offline
I don't care for the foam plugs so I've been using Shure EATFL1-6 - Triple Flange instead on my Clarity Aloft set for 4 years. The triple flange plugs fit the CA headset perfectly, last quite a long time and are easy to clean. They work for me ...
Tom
Port Orange, Fl
RV-12 N121TK ELSA #120845; first flight 06/10/2015
RV-12 N918EN ELSA #120995 Eagles Nest Project
SPA Panther N26TK in progress
Old 01-15-2019, 12:36 PM
scard's Avatar
scard scard is offline
Yep, that is an option. I must say, I've been surprised at how many people like the triple flange (not a lot, but enough). We'll end up carrying some, but it won't be my first recommendation. It has the least noise attenuation of just about any other ear tip. It just goes to show how unique every person and ear are.
Scott Card
CQ Headset by Card Machine Works
RV-9A N4822C flying 1900+hrs. / Cedar Park, TX
Old 01-15-2019, 02:43 PM
Many folks say custom-molded earplugs similarly provide less attenuation than soft foam plugs. As Scott said, everybody is different. My molded plugs fit very well and attenuate noise as well as the yellow Etymotic plugs. And they last forever in my oily ears.
Yup, everybody is different!
Old 01-15-2019, 02:57 PM
Bill Boyd's Avatar
Default custom mold experience
I tried two sets of custom molded ear plugs with my Lightspeeds back in the day. The second set was an attempt to correct an issue with the first set - it didn't.
Seems my ear canal changes shape so much with the position of my jaw that it completely changes the fit of the seal. My option was to fly with my jaw clenched all the time on set one, or have ear canal pain when I did so on set two, which was purposely molded with my jaw in a more relaxed position than the first attempt. The audiologist and I were both discouraged by this, but it was what it was and I ended up selling the Lightspeeds.
So when I get my Card headset, I'm sure it will be soft compliant foam ear tips for me, not molded silicone.
Bill Boyd
Hop-Along Aerodrome (12VA)
Old 01-15-2019, 03:28 PM
DGlaeser DGlaeser is offline
My son made me a 3D printed holder for the plugs I use (doing by hand was very inconsistent). I put the pin in a drill press, center the plug under the pin, heat the pin with my Bernz-O-Matic torch, and then poke it through. I immediately insert the tube, and the hole is gooey enough that it stays put with no glue needed. Pretty easy to keep the tube from going too far. Been doing this for many years.
I applaud the Cards for their new product. Next time I need a headset, I will certainly give them a try.
Dennis Glaeser CFII
Rochester Hills, MI
RV-7A - Eggenfellner H6, GRT Sport & EIS4000, 300XL, SL30, ADI Pilot II, PMA6000, AK950L, GT320,
uAvionixEcho ADSB in/out with GRT Safe Fly GPS
