Old 10-09-2018, 06:43 AM
cajunwings cajunwings is offline
Default Andair Valve Handle
I need to remove the handle from a Andair fuel valve in a RV 7. The locking button covers the center screw securing the handle to the shaft. How does this come apart? Thanks
Don Broussard
RV9 Rebuild in Progress
57 Pacer
Old 10-09-2018, 06:55 AM
krw5927 krw5927 is offline
Don Broussard
57 Pacer
Don, the Andair valve came with a special tool for that screw. It's simply a modified allen wrench, where the short leg of the "L" has been cut even shorter. If you still have the packaging from your valve, it's probably in there somewhere. If not, a new one is easy to make.
You definitely need two hands for this one, and putting the valve body in a vise if it's not fixed in the plane will also help. Pull up on the red knob, and use the modified allen wrench to get at that screw.
Kurt W.
RV9A
FLYING!!!
Old 10-09-2018, 08:26 AM
pazmanyflyer's Avatar
pazmanyflyer pazmanyflyer is offline
http://www.vansairforce.com/communit...handle+removal
Carlos in Arizona
EAA Chapter 538 President, www.538.eaachapter.org
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
Old 10-09-2018, 10:53 AM
If you have a ball allen wrench, you know the rounded ones, that works too.
Tom
Ridgeland, SC
Old 10-09-2018, 12:03 PM
Default Andair
Thanks Team
Don Broussard
