Old 10-09-2018, 09:37 AM
BMC_Dave BMC_Dave is offline
Interesting to learn a bit of history of the NACA scoop and the (non) reasoning it's used in GA.
https://www.flyingmag.com/scoop-naca-scoop
Old 10-09-2018, 09:39 AM
terrye terrye is offline
Default NACA Inlet
Originally Posted by Volumex View Post
So to paraphrase, they are great for air-breathing engines but don't use them for vents.
The original goal of this NACA AR 5I20 investigation and report was to find the suitability of low drag inlets for jet engines, so it is no surprise that the summary specifically mentions this. For example, see figure 38, second to last page where the inlets are shown on the fuselage sides just ahead of the wings. In this position they do not recover much if any ram pressure and you never see them employed in this manner. However, numerous smaller NACA vents are used on the nacelles of pod mounted jet engines for various purposes. They are also used as general purpose low drag inlets.
An earlier post mentioned they should be placed in an area where the fuselage cross section is increasing. A more general statement would be they should be placed in a flow field with a positive pressure gradient. If placed in a flow field with a negative pressure gradient they will act as an exit vent (and not very efficiently). There are lots of examples of poor placement like this on race cars and some aircraft.
To the OP's question, the NACA inlet is not drag free, but I don't think you could measure the difference in speed of your aircraft between one NACA inlet and two.
Terry Edwards
RV-9A (Fuselage)
2018/2019 VAF Contribution Sent
Old 10-09-2018, 09:45 AM
lr172 lr172 is offline
Originally Posted by Marc Bourget View Post
To obtain the design benefit of a NACA scoop you should put it in an area where the fuselage cross-section is increasing. Also pay attention to the "bar" across the aft end of the opening. Proper design requires a substantial radius (compared to most installations seen).
FWIW
Is this "radius" in the 90* corners or a radius'ed edge to the vertical oriented cut in the skin?
N64LR
RV-10 in progress
Old 10-09-2018, 09:49 AM
Thanks for all of the input. It is much appreciated!
N64LR
RV-10 in progress
Old 10-09-2018, 09:51 AM
rdrcrmatt rdrcrmatt is offline
We have them in both sides, no drag difference (same TAS at a power setting) before and after them.
Matt
CFI / RV-10
Old 10-09-2018, 11:40 AM
Good data to know. Sounds an extra scoop may be in my future.
N64LR
RV-10 in progress
Old 10-09-2018, 08:19 PM
vfrazier's Avatar
vfrazier vfrazier is offline
Put the scoop under the wing if possible.
While I only have 2 firm data points, my RV-4 and my F1 Rocket had 11 degree F HOTTER air coming in the fuselage sides than from under the wing. The thermometer doesn't lie.
Believe me, on a 90+ degree OAT day, the fuselage scoops were downright HOT!
YMMV!
Vince Frazier
www.f1aircraft.com
F1 Rocket and F4 Raider components
www.flyboyaccessories.com
RV and Rocket Accessories, Tailwheels, Tools, & More
1-888-8FLYBOY (1-888-835-9269)
F4 Raider - under construction
F1-H Rocket "Crazy Horse" - sold
RV-4 "Chief Pontiac" - sold
Old 10-12-2018, 09:15 AM
cholladay cholladay is offline
For the over head console. I am not sure it matters but I put mine on the left side behind the baggage door. I also have a valve on a servo to help to control airflow. I have tons of air. I sealed up the Vans rear vents during construction. The back seat passengers only use the overhead console. They have never complained about benign to hot.
Chad Holladay
Heritage Airpark TE86
RV-8 N769CE Sold
RV-10 N529W flying
RV -8 Building
Old 10-13-2018, 07:41 PM
Marc Bourget Marc Bourget is offline
It's the inlet edge that's perpendicular to airflow. The "corners" where the curved side edges is 90 deg.
FWIW
