Old 10-04-2018, 10:20 AM
edneff's Avatar
edneff edneff is offline
Default FS: RV-7 IFR CATTO PROP
VANS RV-7
N93MC $109,900 Reason for sale: purchase RV-8
Vans RV-7, 488 hours TT, Engine and Airframe, Standard build, first flight June 2013.
Lycomling O-360 A4M rebuilt with high compression pistons
Catto cruise prop, 165 ktas cruise
IFR, ADS B in and out Full Garmin suite, 3 axis AP, Panel by SteinAir
No damage history, condition inspection due in November.
Hangared at KCCR
EXTRAS / OPTIONS
AERO LED’S WINGTIP AND TAIL STROBES/ NAV LIGHTS COMBO
PLANE POWER ALTERNATOR
OIL QUICK DRAIN
REIFF PRE HEATING SYSTEM
ARCHER WING TIP VOR ANTENNA
DUCK WORKS LANDING LIGHTS AND WIG WAG
TCW 90 MINUTE BACKUP BATTERY FOR AVIONICS
DUAL HEAT MUFFS
EI FT-60 RED CUBE FUEL FLOW
DUPONT IMRON PAINT
SKYBOLT FASTENER COWLING KIT
KOGER SUNSHADE
TRU TRAK SERVOS
PSE PAR 100 EX AUDIO PANEL W BLUETOOTH AND COMM 2
CLASSIC AERO FULL LEATHER INTERIOR AND SEATS PLUS CARPETS
1” FOAM SOUNDPROOFING WALLS AND FLOORS
SCREAMING EAGLE TAILWHEEL FORK
FLYBOYS SEALED BEARING TAILWHEEL
ROCKET STEERING LINK
INLET PLUGS AND CANOPY COVER
CROW 5 POINT HARNESSES
DUPONT IMROM PAINT
HOLLOW AXLE END CAPS FOR QUICK JACKING W/ AVERY TOOL
RIGHT STICK REMOVABLE WITH QUICK DISCONNECTS FOR PTT
UPGRADED HEAVY DUTY SKYTEC STARTER
Panel by SteinAir
Garmin GSU 73 AHRS Backup Battery for AHRS
Garmin GTX 23 Transponder W/ES
Garmin GDU 375 MFD
Garmin GDU 370 MFD
Third GDU Screen already for installation (Panel Cut and Wired)
Garmin GMU 44 Magnetometer
Garmin GTN 650 WAAS Touch Screen Nav/Comm
Garmin GTP 59 OAT Probe
Garmin ADS-B GDL 39 IN/OUT
TruTrak GX FP Autopilot (Made for Garmin)
GMC 305 Auto Pilot Controller
Flight Director
Bob Archer VOR/ILS Antenna
PS Engineering PAR 100 EX Comm/Auto panel
ACK Model E-04 406 ELT
LINK TO PHOTOS: https://goo.gl/photos/5Q3AF5eK3o9gP7sT7
Condition inspection due 11/18
Ed call or text 732-693-9474
eneffinger at gmail dot com
RV7a bought and sold
RV7 bought and flying
ATP, CFIA, II, ME, G
Old 10-09-2018, 09:15 PM
edneff's Avatar
still for sale. Just had the propeller worked on at the Catto factory, zero timed now.
Old 10-10-2018, 11:40 AM
Raymo's Avatar
Raymo Raymo is online now
I think your cruise should be KTAS. Curious what your fuel burn is at that cruise. I cruise at 160 KTAS, 8 GPH, 9.5k-11.5k, 2600 RPM with my 3 blade NLE Catto.
Ray
O-360-A4M w/ AFP FM-150 FI, 1 PMag, Vetterman Trombone Exh, SkyTech starter, PlanePower Alt
All lines by TSFlightLines
NSDQ
Old 10-11-2018, 12:01 AM
edneff's Avatar
You are correct. I will edit my post. see photos provided with actual numbers. Gal/hr is actually lower than shown on the engine monitor, red cube is calibrated on the pessimistic side.
Old Yesterday, 10:59 PM
edneff's Avatar
still for sale, will be undergoing condition inspection shortly.
