Old 09-23-2018, 01:13 PM
lr172 lr172 is offline
Default Filling stall Warning Holes
How did you guys fill the holes in the leading edge for the stall warning device?
I don't have access to the backside of the skin. When filling a hole like this, I like to get a bit of build up to hold the filler in place. If I press it in from the front, there is little likelihood of it hitting the backside of the skin. That leaves me with only .032" of adhesion.
I don't want to pull the fuel tank to get access. These are QB wings.
N64LR
RV-10 in progress
Old 09-23-2018, 01:36 PM
Plummit's Avatar
Plummit Plummit is offline
Mine were just left open Larry. I also have an AOA that has a hole in the top of the wing. No big deal, but if you really didn't want the holes now is the time to fill them.
-Marc
N814RV
2018 Donation made!
ERushing's Avatar
ERushing ERushing is offline
Default Pull the tank
I pulled the tanks to leak test them off the wing anyway. Actually, I pulled the tank twice because the first time I forgot to fill the leading edge holes!
It’s really not that big of a deal.
Eric Rushing
VS, Rudder, HS, Elevator, Tailcone - Complete
QB Wings - Complete.
QB Fuse - In Process. Tail & Fuse are one.
Molalla, OR
Old 09-23-2018, 01:50 PM
togaflyer togaflyer is offline
JB Weld epoxy. Quick set.
Old 09-23-2018, 05:41 PM
DRMA DRMA is offline
I didn't want to pull the tanks either, but decided that it was what needed to be done. Once I started, pulling the tanks wasn't that hard. It took perhaps 30 - 40 minutes per tank to remove and replace them. Then just inserted the rivets to fill the holes per the plans.
Better to remove the tanks now, before they are closed up and installed, then try to fill the holes with some type of mastic and find you need to pull the tanks to do it right 6 months after first flight.
Dave Macdonald
RV-10 Finishing Kit & FWF in-progress
2019 VAF Dues Paid
Old 09-24-2018, 06:44 AM
Scott Hersha Scott Hersha is offline
My QB wings had an inspection plate on the bottom for access to the back side of the holes for stall warning install. If you end up taking off your wings to gain backside access, this is what I did on mine - rough up the skin a little on the inside with some 80 grit, lay a layer of wetted out fiberglass cloth over that area, and then on the outside squeegee on some epoxy/flox over the hole and into the wet cloth. Let it cure, sand to flush, and smooth with epoxy micro paste or metal glaze. sand to 600 grit wet and you'll never see it when painted.
SH
RV6/2001 built/sold 2005
RV8 Fastback/2008 built/sold 2015
RV4/bought 2016/sold/2017
RV8/2018 built/Flying
Cincinnati, OH/KHAO
JAN2019
Old 09-24-2018, 07:42 AM
Is it possible to 3d print a plug that could pop in? You my have to force it a bit.
Since the only knowledge I have of 3d printing is reading Steve's thread, this idea may be nuts. I doubt all the holes are exactly the same size so probably couldnt mass produce them unless they were made a bit bigger and people modified the hole to fit the plug. Just an idea.
rockwoodrv9a
Williamston MI
rockwoodrv9a@gmail.com
O-320 D2A
Awaiting DAR Inspection
Old 09-24-2018, 09:56 AM
flion's Avatar
flion flion is offline
If you REALLY don't want to pull the tanks you could use a pulled rivet. Personally, I think it'd be a bigger hassle to get the rivets from ACS and you'll feel kind of silly once you pull the tanks anyway for some other reason. Plus, even when filled, it won't look as nice as solid rivets.
Patrick Kelley - Flagstaff, AZ
RV-6A N156PK - Flying too much to paint
RV-10 14MX(reserved) - Fuselage on gear
http://www.mykitlog.com/flion/
EAA Technical Counselor #5357
Old 09-24-2018, 11:10 AM
Thanks for the input. I think that I will try some liquid JB weld. If I push it up in there while in the wing cradle, gravity should coat the backside and make it strong enough. I was thinking filler and not something more liquid.
N64LR
RV-10 in progress
Old 09-24-2018, 11:26 AM
rocketman1988 rocketman1988 is online now
Default Yeah...
The issue with filling the hole with rivets is that it is a curved surface. The rivets will give you a flat spot in the curve. Ask me how I know...
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
290 HP Barrett Hung
Wiring...
Dues Paid 2018,...Thanks DR+
